PNY 1080ti Repair
  • baker_jeff
    • 6
    PNY 1080ti Repair
    First post!
    I scored a PNY 1080ti that "functions" but is stuck at 139mhz clock. I can see 3 components are knocked off the board.
    - Capacitor
    - Q571 mosfet
    - Resistor near Q571
    I've only ever repaired MacBook boards before... it's nice having schematics lol. Many hours of googling and I can't find one for the 1080ti.
    Question: Anyone know what kind of mosfet to replace the missing one with? It says "1AM" and a perpendicular "6".
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Re: PNY 1080ti Repair
    1AM is not a Mosfet it is a bipolar transistor
    MMBT3904LT1
    Follow me on YouTube
    Learn Electronics Repair
    • Jane
      How do you test MOSFET in laptops ?
      by Jane
      I tried to use this method:
      Testing an N-channel MOSFET:
      Step 1: Discharge the Gate (turn off the MOSFET)
      Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
      Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
      Step 2: Charge the Gate (turn on the MOSFET)
      Now, place the red probe on the Gate (G) and the black probe on the
      09-27-2024, 03:31 AM
    • Nooy
      VGA MOSfet permanently shorted and loss of MOSfet pad
      by Nooy
      Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
      I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
      02-14-2024, 02:26 AM
    • redbaron1007
      Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
      by redbaron1007
      I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
      Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
      09-09-2025, 11:10 AM
    • AppleLover123
      Asus X712EA 3 volts after the first mosfet
      by AppleLover123
      Hey guys,
      i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
      I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
      Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
      I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
      Now i thought something...
      12-15-2024, 07:49 AM
    • MicroSMD Lab
      ASUS ROG Zephyrus GPU Mosfet repeat failure
      by MicroSMD Lab
      The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
      I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
      01-10-2024, 06:36 AM
