SOYO P4I845GVISA PLUS - Bad Caps Confirmed
  • Sigmo
    • Apr 2010
    Just another data point for everyone.
    We've got about ten SOYO P4I845GVISA PLUS motherboards in use for data acquisition systems because they've got three ISA slots to support legacy ISA data acq boards.
    We've recently had three of them fail within about a month of each other. One had operated for about 9 months. One for about a year and a half, and the other had operated for only a few weeks.
    Inspection of all three bad ones shows that many of the caps in the CPU core voltage conversion area are bulged and have leaked out their tops.
    The bulged/leaking caps are all SACON SZ5 10 and SACON SZ602.
    The remainder of the electrolytics on these boards are SACONs or EVERCONs. They look very similar except that the EVERCONs have a "cross" shaped vent/relief pattern on their tops while the SACONs have the "K" shaped vent/relief pattern.
    I ordered new caps for every cap on these boards, and got enough to do five boards. Today, I got the caps and "recapped" the board that had failed after a few weeks, and it is running fine now. I plan on recapping the two other dead ones when I get the time, and there is one MOBO we have never used and I'll recap it before we put it into service.
    I'm hoping this will make these boards reliable in the long term.
  • mockingbird
    • Dec 2008
    • 5484
    Re: SOYO P4I845GVISA PLUS - Bad Caps Confirmed
    Ah poor Soyo. The good ol' days.
    • c_hegge
      • Sep 2009
      • 5219
      Sacon = Evercon = GSC = VERY unreliable. The worst cap brand in the world (maybe tied with Fuhjyyu).
      • Sigmo
        • Apr 2010
        Yep. They're not very good in our experience! That's why I replaced them all.
        I will say that it was a royal pain cleaning out the holes for some of the caps where they have large areas of foil on both sides of the board that are both connected directly to the lead-holes.
        Apparently whoever did the board layout for Soyo has ever heard of a thermal relief.
        Then again, they probably cannot imagine in their wildest dreams that anyone would actually repair a motherboard instead of just pitching it in the trash. But in this case, we're stuck because it's not too easy to find mobos with ISA slots these days!!
        • phatjmo
          • Sep 2010
          I also have this model motherboard with the exact same cap failure. Everyone wants $300 for an ISA MB like this so I want to try replacing the caps as a cheap alternative, Sigmo, where did you purchase those caps and what models did you order? I can't seem to find much on those caps though I have to admit I have no idea what I'm doing.
          • c_hegge
            • Sep 2009
            • 5219
            Rubycon MCZ and MBZ would be OK
            https://www.badcaps.net/pages.php?vid=22
            • TheLaw
              • Jan 2011
              • 477
              Friggin Evercon. Never got around to recapping my EVGA FX5500, but it was 100% Sacon FZ + a couple of Evercons. Nothing blown yet....but I'm never buying EVGA again because of that.
              Evercon: Replace them. They suck.
              You could try Nichicon HM. They might be cheaper than Rubys, but Rubys might be a tad better quality. HMs are pretty darn cheap, I believe.
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5042
                • US
                I have a P4I845PE with the same thing. Bunch of 3300 6.3
                a bunch of 1500 16 with K stamps that aren't bloated
                does work, but I don't trust it. Still 800 P4 capable
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  On those old Soyo boards you also may find silver OSTs which look to me to be fakes.
                  If you look at the bottom photo in post #1 you can see how the vent is stamped AFTER the sleeve was in place.
                  You can tell because the sleeve material is pressed into the groves in the vent.
                  That is very unusual. [rare even]
                  I think I've only seen it on Soyo boards with silver caps.
                  Thing is I've seen the same exact abnormality on Soyo w/ silver caps branded OST, Evercon, Sacon, Capsun, -and- GSC [on both socket 370 and 478 boards].
                  Suggests to me they all came down the same assembly line no matter what the name is on them.
                  [Yes, it's possible someone was stupid enough to counterfeit Sacon and Evercon...]
                  Also note illegal use of trademarked K vent in photo.
                  ( Mine didn't have that I don't think.)
                  - But it's another sign of a counterfeiter at work.
                  All of that said,, Soyo boards work great once you get good caps on them.
                  Mann-Made Global Warming.
                  - Dr Seuss
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5042
                    • US
                    yeah these were sacon
                      by momaka
                      03-12-2025, 03:42 PM
                    • eryjus
                      by eryjus
                      05-10-2023, 11:21 AM
                    • Paxman_Swede
                      by Paxman_Swede
                      Hello!
                      01-14-2025, 09:51 AM
                    • captain150
                      by captain150
                      03-16-2025, 07:34 PM
                    • Foetuss
                      Gigabyte GA-6OXT :: caps question
                      by Foetuss
                      Good evening
                      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                      But I was also suprised about the bigger boys, which are 330µF 25V.
                      Could it be they used 25V caps because they were cheaper / available at that time?...
                      02-11-2025, 12:22 PM
