Logitech MX Master 3 dead
  • paparazzo79
    • Dec 2018
    • 303
    • Bosnia
    I started having issues with this mouse on my laptop.
    Sometimes it works something don't.
    The only way when it stops to work to make it work again is to push usb dongle little upwards,probably so it can make better contact with USB port on laptop.
    But from this morning it doesn't work at all.
    On same USB port other wireless mouse works pretty normal.
    I tried on second laptop same MX master,northing simply dead.
    Now I plugged in USB dongle to one of my desktop PC which really has nice USB port and dongle doesn't move at all while trying to move it left to right,and guess what,mouse works normally.
    Wtfff is going on here? 😕
    Anyway I ordered same MX Master 3.
    Did I make a mistake when often transferring USB dongle to other laptops and using mouse.
    I guess probably such small devices are not meant to remove/install over and over again.
    Update 03/10/21
    I remember mouse fell on a floor few days back..
    I've disassembled the mouse now and gesture button is not blocked,works normally.
    But the mouse is simply dead,,cursor does not move but the sensor does register the move (I get green light on mouse).
    Thumb buttons sre not registed either.
    I'm sending pics so if anyone see smth suspicious please let me know.
    Is there a way to fix it?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: MX Master 3 dead
    Sounds like a loose contact or dry joint on the USB dongle.
    • paparazzo79
      • Dec 2018
      • 303
      • Bosnia
      How to resolve that?
      • diif
        • Feb 2014
        • 6978
        • England
        Inspect and resolder any cracked joints.
        • paparazzo79
          • Dec 2018
          • 303
          • Bosnia
          I get a message that usb dongle is plugged in, so laptop detects it.
          But mouse is dead.
          Is there a chip in dongle?
          • diif
            • Feb 2014
            • 6978
            • England
            Your wrote this "The only way when it stops to work to make it work again is to push usb dongle little upwards,probably so it can make better contact with USB port on laptop."
            This is refering to the USB dongle?
            • Tygarbyte
              • Jul 2021
              • 5
              • australia
              Does the scroll work ??
              Try loosening those screw 1\2 turn or loose enough to click or remove it altogether if you dont use it.
              • paparazzo79
                • Dec 2018
                • 303
                • Bosnia
                Did tried that,nothing.
                I purchased another same MX Master 3 and installed it's dongle thinking that older mouse might work with it.
                But not!!
                Wtf!!!
                I will take it to a guy who repairs PCs and pray to God the issue is within USB dongle.
                Somehow this plastic on USB dongle is a little loose.
                But I ain't sure how we are going to fix this.
                I hope mouse is okay,though it fell on the floor,I don't see anything suspicious except it could be some bad electronics issue.
                I think these errors are hard to repair.
                • paparazzo79
                  • Dec 2018
                  • 303
                  • Bosnia
                  yes.
                  But from Monday it doesn't work at all,even when slightly moving USB dongle upwards.
                  • paparazzo79
                    • Dec 2018
                    • 303
                    • Bosnia
                    Re: Logitech MX Master 3 dead
                    I took the mouse to a local repair guy,he told me that mouse is okay,but there is a problem in USB receiver detecting the mouse,it simply won't recognize it.
                    So I want to ask you can I purchase separately USB dongle from the link below and would it work with the mouse?
                    Or each mouse needs it's own USB receiver?
                    https://iponcomp.com/shop/product/lo...ceiver/1583740
                      • 22130
                      The receiver/unifying receiver has to be the right part number.
                      Have you tried updating the firmware
                      https://support.logi.com/hc/en-gb/articles/360035037273
                      https://support.logi.com/hc/en-gb/articles/360025297893
                      • paparazzo79
                        • Dec 2018
                        • 303
                        • Bosnia
                        No sorry I didn't, just because mouse worked without an update.
                        So each receiver works just with it's own mouse,correct?
                        While trying to remove the usb receiver,metal part stayed in usb slot (pic).
                        How do I remove it now?
                        Did I make a short on USB port this way because laptop was ON,when I wanted to remove it.
                        https://ibb.co/NtxV38s
                          • 22130
                          Oh dear,so the dongle is broken.Before you even attempt to remove the rest of it from the port you should disconnect your battery, just in case that port is powered.You dont want to short the data lines with 5v or you will kill the CPU.
                          There should be a part number on the plastic part or the usb metal part of the dongle.
                          • paparazzo79
                            • Dec 2018
                            • 303
                            • Bosnia
                            Took it to local repair service and guy did manage to remove metal shielding from USB port,we turned ON laptop and works okay.
                            I guess I was lucky.
                            Yes there is a part number,but what with it?
                            Logitech don't ship to Bosnia.
                            • paparazzo79
                              • Dec 2018
                              • 303
                              • Bosnia
                              I did unpair the unifying reciver via special software by Logitech and then tried to pair back,nope no luck...Mouse simply won't recognize the receiver or vice versa...
                              I don't think I can now update firmware suggested by logitech but don't think that is causing the issue.
                              Weird thing is that mouse it doesn't even work over it's USB cable as regular mouse,which makes me think something bricked the mouse.
                              • paparazzo79
                                • Dec 2018
                                • 303
                                • Bosnia
                                I did finally manage it to work but via BT option,but on channel 2.
                                Somehow simply it won't work on channel 1,number 1 flashes but nothing.
                                Dunno if it's possible that for some reason mouse is bricked with USB receiver on channel 1.
                                I can try once more to pair over channel 1 but rather wouldn't want to..
                                So what would be my next step.
                                This is a success to me,cuz I want to throw mouse into garbage.
                                But over USB receiver no matter whan channel I select it wouldn't pair with the reciever.
                                • paparazzo79
                                  • Dec 2018
                                  • 303
                                  • Bosnia
                                  Logitech unifying receiver repair
                                  Guys,anyway to assemble this back as it was previously (like new)?
                                  Logitech doesn't want to send replacement one.
                                  Not my fault, took it to local repair guy and he opened the receiver.
                                  Now the plastic part comes from metal housing each time I plug receiver to usb port.
                                  • brethin
                                    • Dec 2008
                                    • 1907
                                    Re: Logitech unifying receiver repair
                                    Hot glue always worked for me.
                                    • paparazzo79
                                      • Dec 2018
                                      • 303
                                      • Bosnia
                                      Don't have a heater.
                                      Can super glue help?
                                      • sicilianul
                                        • Jul 2014
                                        • 70
                                        • Romania
                                        buy a new unify receiver, any.... It will work 100%
                                        • Omron
                                          Logitech G203 Prodigy Gaming Mouse
                                          by Omron
                                          Hello guys, my mouse left click started to double click,
                                          I unsoldered side click and swapped it onto left click, everything was great, but I was left with only 1 side button click, instead of two.
                                          Then I found another switch from other mouse and I got an idea to solder it back onto thumb button, so everything would be working properly.
                                          This is where things went south, pretty fast.
                                          When I was soldering it, apparently I burned the pads, so I tried to bypass them following the path.
                                          (pictures uploaded below, basically I connected two purple...
                                          04-23-2023, 03:07 AM
                                          Acer TravelMate P214-52-566U+15.6" Bag&Mouse Notebook P2 Specification for Upgrade or Repair
                                          This specification for the Acer TravelMate P214-52-566U+15.6" Bag&Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P214-52-566U+15.6" Bag&Mouse boardview and P214-52-566U+15.6" Bag&Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-06-2024, 07:20 PM
                                          Acer TravelMate P215-52-56G5+15.6" Bag&Mouse Notebook P2 Specification for Upgrade or Repair
                                          This specification for the Acer TravelMate P215-52-56G5+15.6" Bag&Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P215-52-56G5+15.6" Bag&Mouse boardview and P215-52-56G5+15.6" Bag&Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          Acer TravelMate P214-52-54NA+15.6" Bag&Mouse Notebook P2 Specification for Upgrade or Repair
                                          This specification for the Acer TravelMate P214-52-54NA+15.6" Bag&Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P214-52-54NA+15.6" Bag&Mouse boardview and P214-52-54NA+15.6" Bag&Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          HP EliteBook 840 G6 + Elite Presenter Mouse Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 840 G6 + Elite Presenter Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + Elite Presenter Mouse boardview and 840 G6 + Elite Presenter Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-06-2024, 05:00 PM
