Hello guys, my mouse left click started to double click,
I unsoldered side click and swapped it onto left click, everything was great, but I was left with only 1 side button click, instead of two.
Then I found another switch from other mouse and I got an idea to solder it back onto thumb button, so everything would be working properly.
This is where things went south, pretty fast.
When I was soldering it, apparently I burned the pads, so I tried to bypass them following the path.
(pictures uploaded below, basically I connected two purple pins together), but then even click 1 thumb button when I clicked it it shut off my keyboard.
So I unsoldered click2 on thumb and still left click on thumb button when I clicked it it shut off my keyboard, I couldn't use it anymore. even if it was not touched returned to factory new state.
So I ended up having thumb_click board removed...And I wanted to ask if someone have like boardview for this mouse, to see how I could connect switches. Below I uploaded pictures, my question is, purple circle pins (NC Terminal), where do they connect? I thought its ground so i wanted to grind on board to find it but I couldn't.
also could it be cause of me connecting NC terminal on both clicks to cause some short on board to make my keyboard not functional when I click that click1_thumb_button?
Its little bit confusing I wrote plenty of things but hopefully you guys can understand what I tried to say, and if not, feel free to ask me
thank you for reading!
but yes, works perfectly
