hard driver ibm 527mb component getting hot
  • dellxps15
    • Feb 2014
    • 1588
    • italy
    hi all, i was resurrecting an old pc intel 486dx2 66mhz and all was working just fine, except one component of the hard drive getting a bit hot... after one hour, hdd didnt spin annymore and i see it is taht component that is getting extremely hot. after cleaning and inspecting, i noticed that on the 5v fuse i had 5 volt one side and 1,38 on hte other side, so i removed the fuse and injected volt and got that chip getting very hot soon. now problem is that i cant find that chip anywhere
    component is hd153031sf. ive found it also on nintendo 64dd and should be an hitachi branded mcu. does anyone know what is that or a similar ic to replace it with ?i attach some picture taken from the nintendo 64dd on the internat, as they are the same.
    i really hope to find that part for cheap price, since ok old hdds are expensive now , but if i should pay too much ill go with ide to sd adaptor that i already have at home
  • osrex
    LED DRIVER KEEPS DYING
    by osrex
    Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
    i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
    i have no datasheet at all for the LED lights, all i have is its length.
    long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
    as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
    05-05-2025, 03:36 PM
  • federalhouse
    **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
    by federalhouse
    I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
    **Background:**
    I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
    **What I've Tried So Far:**
    1. I accessed
    08-01-2024, 07:03 PM
  • howardc64
    Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
    by howardc64
    Problem
    Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
    Model & Board Pics
    Conflicting Spec
    Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
    https://www.shopjimmy.com/vizio-gj-2k1...
    10-10-2024, 01:16 PM
  • charif
    Audio Driver for Thomson P14C4BK128
    by charif
    Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
    I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
    The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
    Here are the details:
    • Model: Thomson P14C4BK128
    • Operating System: Windows 10 64-bit
    If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
    Thanks in advance for your help!
    04-30-2025, 05:41 PM
  • bohaboha
    how to install gl usb2.0 uvc camera device driver on windows 10
    by bohaboha
    Hello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encou​ntered an error.
    but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
    any help?
    01-26-2025, 08:33 PM
