Unlock HP z840 Manufacturing Mode
  • wmn
    • Jul 2021
    • 5
    I need to unlock the HP z840 Manufacturing Mode to restore the TPM functionality of the motherboard.
    Is that possible?
    I have posted a thread on HP Support forum without success.
    https://h30434.www3.hp.com/t5/Busine...s/td-p/8103194
    Thank you.
  • peste
    • 13557
    • ROMANIA
    Re: Unlock HP z840 Manufacturing Mode
    Is that possible?
    Thank you.
    try this..
    https://www.youtube.com/watch?v=9T57ktw8n3Y
    • wmn
      • Jul 2021
      • 5
      this tool is the HP BIOS Configuration Utility (BCU)
      latest version can be downloaded here:
      http://ftp.ext.hp.com//pub/caps-soft...it/HP_BCU.html
      It gives me error when trying to unlock the MPM:
      <SETTING changeStatus="fail" name="Manufacturing Programming Mode" reason="SetBIOSSetting: Access Denied" returnCode="6">
      <OLDVALUE><![CDATA[Lock]]></OLDVALUE>
      <NEWVALUE><![CDATA[Unlock]]></NEWVALUE>
      </SETTING>
      <ERROR msg="Failed to set BIOS config" />
      <Warning msg="BCU return value" real="16" translated="16" />
      </BIOSCONFIG>Process Completed Successfully.....
      It will not unlock the MPM.
      Thank you for your feedback.
      • wmn
        • Jul 2021
        • 5
        I read this document:
        Instructions on CREATING the MPM-Unlocking SMC.BIN USB Drive
        https://manualzz.com/doc/44691860/in...ng-smc.bin-usb
        I tried using HP NBDmiFit tool
        https://www.finalfixer.com/2020/02/h...mifit-all.html
        But the included FSMC.bin that you rename as SMC.bin is not working on the z840.
        At least I followed the procedure described in the above pdf without success.
        Thanks.
        • wmn
          • Jul 2021
          • 5
          hi,
          I tried the UefiMpmUnlock.efi but i got "HP MPM protocol is not present."
          so what else I can do?
          Thank you.
          • AustinCER
            Dell XPS 8940 | Manufacturing Mode? | No Service Tag
            by AustinCER
            Hello, I currently have a Dell XPS 8940 in our office for repair.
            Service Tag: HG1Y673
            The most recent BIOS is pictured below -- being available as an .exe on Dell website.
            Needed a new motherboard due to power surge. The motherboard replacement was installed and upon power up it was booting to a display message - Manufacturing Mode Active -
            Have not dealt with this issue before or what the proper steps are. I booted to the BIOS and manually entered the Service Tag, but upon each reboot -- the service tag is wiped and shows the Manufacturing Mode display message,...
            07-15-2025, 05:28 PM
          • jlxxxx
            Dell 9310 (2-in-1) bios to fore manufacturing mode
            by jlxxxx
            I have read the FAQ, and other reference here to changing the EC region of the flash image to force entering manufacturing mode.
            How would I modify the dell 9310 firmware in order to force entering manufacturing mode? The goal is to have the computer ask me to enter the service tag after changing the motherboard.
            Can this be completed using the boot-up USB restore method that Dell supports in order to reduce risk of damaging the hardware further? (Ctrl+Esc keys while holding the power button)
            Dell provides this bios here: https://www.dell.com/support/home/en-us/drivers/dri...
            09-25-2024, 02:38 PM
          • CapThatBrass
            The Mystery of 'Manufacturing Mode' - Dell Motherboards
            by CapThatBrass
            Firstly sorry if this is the wrong forum for posting this question - please recategorize or move to another part of the forum if necessary.
            I've been doing alot of research recently into the world of BIOS editing and building of images, out of curiosity mainly.
            Lots of Youtube videos as well as threads in this forum (as well as others) mention the term 'unlocked' bios which generally means the removal of BIOS passwords from a dumped image to allow full access to the BIOS/UEFI menu. However, a handful mention that a prompt for the Service Tag will...
            11-04-2022, 04:59 PM
          • DynaxSC
            Stubborn GIGABYTE B365M AORUS ELITE - main PCIe x16 GPU port working only in x8 width mode
            by DynaxSC
            I have this board, where I have exchanged the LGA1151 socket. During testing I discovered, that the large PCIEX16 slot won't by no force work in x16 mode, but keeps to work in x8 mode only.
            I tested this with GPU-Z, also with Render Test (but tried also Furmark and Heaven Benchmark - no effect).
            Tested on Core i5-9600K as well as on an Pentium G5420 and MSI NVIDIA GTX1070 and 2 other cards, including RTX3060Ti.
            Board architecture definitely allows x16 mode, as all 16 PCIe lanes are present between CPU and main GPU slot (nearest to CPU).
            05-04-2025, 12:08 PM
          • f-bone
            Lock manufacturing mode is HP by modifying binary file of BIOS
            by f-bone
            hi guys,
            wasn't sure where to place this (BIOS requests or here).
            i know the software procedure to re-lock the manufacturing mode in Windows but is there some hex editing to the .bin file that would do that just before I flash a new .bin to the SPI?
            thank you in advance,
            george
            09-12-2024, 02:27 AM
