Soyo SY-7VEM
  • makk
    • Aug 2005
    • 8
    Soyo SY-7VEM
    This board was completely covered with Wendell brand capacitors, mostly 1000uf 6.3V and 1500uf 6.3V. Every single one of these were bulging.
    Of course the machine had gotten extremely unstable and would reboot itself or park the IDE drive randomly.
    I recapped it with Rubycon MBZ's, 1500uf 10V and 1000uf 10V. The machine works GREAT now, although the BIOS hardware monitor now says that all the voltages are higher than what they should be... e.g. 12V rail reads 12.5, etc. Not sure if this is a side effect of using 10V caps, as I don't remember if the hardware monitor reported higher than normal values before. Also changing power supply has no effect on these high values.
    When I get a chance I'll take the board out the case and check the real voltages with a DMM.
    Other than that, I left it running Sandra burn in for a whole day and no crashes, so I think it's good-to-go.
  • Kingpin!
    3COM OfficeConnect Gigabit Switch 16
    by Kingpin!
    3COM OfficeConnect Gigabit Switch 16 (3C1671600)
    The switch has served me for 10+ years (was new when I bought it). It's a nice switch with connections on the back which makes for quite a clean desk. Reason for taking it apart was that the cooling fan was noisy so I expected it to be dirty/dusty inside and the need to order a new fan. What I found was that it was very dirty/dusty and some electrolytic capacitors which needs attention. There are 3 capacitors which needs to be replaced but the ESR on some of the other ones might be bad as well so I think I'll replace them all. Original...
    09-17-2023, 04:58 AM
  • rattlesnake
    Soyo SY-7VBA133U recap
    by rattlesnake
    Hi guys,
    I'm going to recap this baby. I found it dumped in the street years ago, and now it's time has come. I remember having tested it and it posted back then.
    Original caps are bulged and look nasty. All are SACON
    11 x 1000uF 10v
    12 x 1500uF 10v
    1 x 470uF 16v
    11 x 22uF 25v
    1 x 10uF 25v
    The smaller ones look fine. Should I replace them too?
    I read on another forum that I could replace the 1500uF caps with 2200uF caps. Is that so?
    The thing is I could get Sanyo 2200uF or Capxon 1500uF (or Jackon 1500uF)....
    04-10-2022, 06:47 AM
  • Junkrepair
    Calculating ESR from tan delta -- tan delta's dependence on capacitance
    by Junkrepair
    I'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
    I found this nice little description of the conversion:
    Calculating capacitor ESR from Tan(delta)
    https://forum.digikey.com/t/calculat...-from-tan/2633
    It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...
    06-12-2023, 02:45 PM
    I need to order some 1000uf @ 16 volt it has to be 8mm in diameter what is a good choice
    Here is the page of capacitors that I can choose from what is a good choice for a FSP 400-60GLC
    https://www.digikey.com/en/products/...Xmc1YPJ6BlESoA
    I try to use a 565-1664-ND which is a 10mm in diameter unfortunately it will not fit because there are two of them the same size and value and there is no room and they go to two different circuits not in parallel...
    08-03-2024, 02:54 PM
  • frannyjunk
    Vizio M60-C3 Replacing 1000uF 16V with 1000uF 35V capacitors?
    by frannyjunk
    Hi, my Vizio M60-C3 does not power on. No lights whatsoever. Upon opening up the TV, the power supply board has 4 bulging capacitors. Each is 1000uF 16V. I have read that one can use capacitors of the same uF and higher voltage rating, but is 1000uF 35V capacitor too high of a voltage rating? My local shop only has these higher voltage capacitors so would rather just buy the 35V variety if it is OK to use them.
    Any thoughts if OK to use these higher voltage capacitors?
    11-04-2021, 05:59 PM
