Abit KT7A successful recapping
  • makk
    • Aug 2005
    • 8
    I have two of these boards, an Abit KT7A and a KT7A-RAID. The KT7A is about a year older than the RAID.
    It seems to me that the first caps to go on these boards are the three 1500uf 6.3V ones near the AGP slot. On my KT7A, these were bulged visibly (Jackcon brand). On my KT7A-R, these didn't show any visible signs of deterioration, but I kept getting blue screen errors that referred to an Nvidia driver, and the machine was generally unstable.
    After recapping both boards completely with Rubycon MBZ series, they are running remarkably well.
    Interestingly, I was using a Duron 1.1 with 200MHz FSB with the KT7A-R and I was unable to run the RAM asynchronously at 133MHz (Host CLK+33) when the board was brand new but it works beautifully now! So you could say after the recapping it is better than new. I've left these machines running a Quake 3 timedemo loop overnight and no crashes yet.
    I used a Nicholson 30W iron with a medium sized tip. After removing the old caps, I didn't bother to clean the holes, instead pushing the new caps through the old solder. This seems to work fine. I know Topcat et al would not recommend this, but I've done 4 boards and a network switch power supply this way and no issues yet.
  • Chris1992
    • Apr 2005
    • 561
    Re: Abit KT7A successful recapping
    Congrats. Pics? Where did you get the MBZ, as far as I know Digikey does not sell them.
    The great capacitor showdown!
    • Newbie2
      • Sep 2005
      • 885
      makk could of got the Rubycon MBZ caps from Topcat's capacitor kits or a website we currently do not know of.
      My gaming PC:
      AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
      ASUS M4A77TD AMD 770 AM3 Motherboard
      PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
      G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
      TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
      WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
      ASUS Xonar DG 5.1 Channel PCI sound card
      Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
      Antec Three Hundred Mid-Tower Case
      Microsoft Windows 10 Pro 64-bit
      Microsoft Windows 7 Ultimate SP1 64-bit
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        great stuff Makk, i am happy to see success stories
        this is ok but important to heat the solder pads and not push hard
        • yanz
          • Nov 2004
          • 910
          i love mbz caps. do u know that u can replace all 2200uf on that kt7a with 1500uf 10v mbz? its not that i recommended it but it works like a charm for my 1200mhz duron @ 1300mhz (10+ mhz fsb oc). it's been one of my folding rigs and works 24/7.
          days are so short when you actually do something..
          • OldeCrow
            • May 2005
            • 18
            Originally posted by makk
            ... I know Topcat et al would not recommend this, but I've done 4 boards and a network switch power supply this way and no issues yet.
            hehe... I use a cheap "ripoff shack" desoldering iron to remove and resolder the new caps in most cases. the only time I break out the real iron is if the space is too tight for the desoldering iron .. its a pretty good trick cuz the desoldering iron will hold solder in the suction hole in the center of the tip and as long as you are carefull when desoldering the varnish on the pcboard will keep you from oversoldering when you resolder the new caps .. of course I've been soldering since I was 6 years old and Ive been told that I could solder better with a hot fire poker than most people do with a good iron so perhaps the novices should follow Topcat's advise on soldering and desoldering
            • cloppy007
              Abit NF7-S 2.0 short while recapping the AGP cap?
              by cloppy007
              Hello!
              I have an old Abit NF7 that was stored after working OK and when I took it out of storage it didn't boot at all. I saw that the nichicon capacitor right under the AGP port was visibly damaged and today I proceeded to replace it with an equivalent Panasonic FR (EEUFR0J182).
              Prior to that, I measured the ESR value of both the new one (0.024 ohms) and the bad one (>1 ohm) using an aliexpress meter (MESR-100 v2). As everything seemed ok, I went ahead.
              Besides a very poor solder job on my part I went to check resistance and continuity (just for...
              08-12-2022, 11:39 AM
            • proxneo
              Recapping Sony ICF-SW55 - verifying cap values
              by proxneo
              Dear reader
              I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
              At the moment, I have selected replacements based on the following list of values:
              3 x 470uF 10VDC
              3 x 4.7uF 35VDC
              4 x 47uF 50VDC
              8 x 22uF 6.3 VDC
              1 x 220uF 6.3VDC
              5 x 100uF 6.3VDC
              Which...
              06-21-2023, 12:38 AM
            • ziplock
              Abit BE6-II motherboard
              by ziplock
              Greetings,
              I have an Abit BE6-II motherboard that posts sporadically with the bare minimum components installed - CPU, RAM, PSU, and a Keyboard. I know it posts when the speaker beeps. Re-seating the components has no effect.
              I thought the sporadic posting might be capacitor related. Upon inspection, non of the caps are bulged or leaking and they are all original. So, I pulled them ALL. While the ESR is OK, over half of them are leaking current between 1 and 2 mA. The biggest offenders are way out of spec, like a 1500uf / 6.3V measuring 2600uF and many of the 820uF caps...
              04-20-2025, 02:09 PM
            • Foetuss
              Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
              by Foetuss
              Hi all
              Hope this is in the correct place.
              I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
              Could use some double checking to see if I'm not doing something stupid .
              Pictures of the boards are attached.
              What I will be replacing with what : (planned)
              Soltek Golden ::
              4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
              6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
              01-18-2025, 11:44 AM
              ABit IP35 Pro Motherboard Schematic
              ABit IP35 ProABit IP35 Pro Motherboard Schematic
              A motherboard based on the Intel P35 Bearlake-P+ RAID chipset....
              10-31-2024, 02:06 PM
