ALDI MEDION MD9783/Md5275 motherboard
  • 2ndhandsony
    • 6
    Board is dead,no power. Anybody work on these and have a solution? Who supplies ALDI Medion with motherboards? thanks
    • 31055
    Re: ALDI MEDION MD9783/Md5275 motherboard
    MSI aka MicroStar International.
    • 2ndhandsony
      • 6
      Have you worked on these boards? do you have a MSI part number?
        • 31055
        msi part number is on the motherboard.
        usually starts with MS-
        • c_hegge
          • Sep 2009
          • 5219
          See if it powers on with the 4-pin 12v connector for the CPU unplugged. If yes, then you have a shorted CPU VRM. If no, then the trouble lies elsewhere.
          • glovecaps
            Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
            by glovecaps
            I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
            My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
            The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
            11-25-2024, 04:23 PM
          • Docus
            Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
            by Docus
            Hi everyone 😀,
            I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
            To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
            Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
            1. I already own the exact same model, but its plastic chassis is badly damaged.
            06-10-2025, 04:24 PM
          • Archimedes
            HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
            by Archimedes
            Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
            Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
            Fans are spinning. Blindly could install windows11 and got the device manager...
            07-30-2024, 05:14 PM
          • acedogblast
            by acedogblast
            11-02-2024, 05:13 PM
          • dhenion
            Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
            by dhenion
            I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
            The original board was:
            ASUS X510UNR REV 3.0 A
            The replacement board is:
            ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
            It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
            01-30-2024, 01:45 PM
