Sapphire Nitro RX 470 issue with bios / black screen / blue screen
  • LowVoltage
    • Oct 2020
    • 5
    • SRB
    I've gotten myself a supposedly "Sapphire Nitro OC+ RX 470 8GB" in "untested" condition.
    When I came home and plugged monitor cable directly in it, my computer wouldn't post with it / no display.
    I then pulled the card out, set bios settings so that primary display is integrated gpu, plugged in back the RX 470 and I got into windows.
    In device manager the computer could see it, it was recognised as RX 480 with code 43, I immediately thought it's just a bad bios flash, went to Gpu-Z to check what currently is flashed, and found out it's flashed to Samsung 4GB memory..
    I opened the card up, inspected memory chips, inspected the board, googled a bit and it turns out the card is actually RX 480 4GB, the seller just put backplate of RX 470 8GB to get more money out of it. I then downloaded original bios for RX 480 Sapphire nitro with 4GB Samsung memory, I wasn't getting code 43 anymore, I couldn't get into Windows at all with original bios.
    I tried every bios that would fit my card and I can't get it to post directly with monitor cable plugged into card with proper bios, if I try to boot with igpu as display and proper bios installed, PC would either freeze on windows loading, or blue screen with error such as "thread stuck in device driver", "tdr video delay" or just black screen until it reboots itself. So i'm pretty sure it's hardware problem now, just unsure what to look for next, is it most likely to be a bad memory chip, bad gpu chip or could it be something like a bad resistor or something minor?
    Any help or directions are appreciated !
  • ermak72
    • May 2021
    • Russia
    Re: Sapphire Nitro RX 470 issue with bios / black screen / blue screen
    bad memory chip
    • mitchw
      HP 14s-fq1010nm Black screen after BIOS update - cannot downgrade
      by mitchw
      Just had a customer bring in a HP 14s-fq1010nm to do some maintenance.
      After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
      After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
      I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...
      04-29-2025, 03:45 PM
    • BlueNitesFire
      I need Lenovo yoga 6 13ARE05 bios- broken screen and no bright light on keyboard
      by BlueNitesFire
      So I couldn't remember my bios password and since it was broken screen, I used to connected to the TV via Type C to HDMI. So I decided to remove the Bios chip and reprogram the Bios chip with ch314a.. when I try to solder Bios on the laptop, one of the Bios leg broke off.. I bought a new blank Bios chip so I can programmed by flashing on the bios.
      03-08-2025, 03:49 PM
    • Technodoc
      ASUS G614JZ G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
      by Technodoc
      Asus laptop G614JZ-N3012W Rog Strix with i7
      Mainboard G634J-PMV-VGT
      6050A3441302-MB-A01
      2023-02-10
      Power button works okay....power light goes on
      Red "bottom" leds go on
      Charging led works
      Fans do not spin, capslock key does nothing, screen stays black
      I would like to program the bios again, to rule out a corrupted bios.
      However I run into a size error
      The bios chip is a Winbond 25R256JVEN
      Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
      02-24-2025, 04:46 AM
    • jbonavita
      by jbonavita
      Some issues
      Things I tried
      04-29-2025, 09:38 PM
    • zenius
      by zenius
      12-08-2024, 06:13 AM
