DFI NFII-Ultra
  • Colt45ws
    • Jan 2009
    • 174
    DFI NFII-Ultra
    My Mom had a machine I built a couple years ago with this board. It had been giving her lots of trouble as of late and I replaced it. Well, I was hoping I could use the board/cpu/memory to replace same in my server, which is on a ECS K7S5A, which I noticed is starting to blow caps when I dusted it last month.
    Of course its not that simple and the NFII is to the point of launching caps.
    I actually have no idea how it was running at all. No wonder it wouldnt stay running.
    Just as an experiment, Im going to try recapping it. If it works, new server. If not, 5.56x45mm..
    Heres a pic of the VRM area.
    Do you think there is any latent damage to the board from that one venting onto it?
    I got these cap sizes.
    16v
    470uf x4
    1500uf x4
    10v
    1000uf x3
    6.3v
    3300uf x6
    1000uf x5
    470uf x2
    I can just replace those 10v parts with 6.3v ones right? Seems to be alright from my reading. I cant seem to find any 6.3v 470uf parts. 16v would be alright there?
  • weirdlookinguy
    • Sep 2007
    • 1638
    Re: DFI NFII-Ultra
    Colt 45, and two zig-zags, baby that's all we need...
    If the board still POSTs, but is just unstable, there was most likely no lasting damage.
    • Colt45ws
      • Jan 2009
      • 174
      Re: DFI NFII-Ultra
      Yeah, it was running right up until I shut it down to replace it. What can I use to remove that stuff? I already decapped it since I was bored. I ended up just buying VRM replacements for now along with ones for those little Teapo 470uf caps which are right next to the 12v CPU feed. I got Samxon for those and the 12v side of the VRM and Rubycon for the low voltage side.
      • kaniki
        • 514
        Re: DFI NFII-Ultra
        For the voltage on the caps. it is usually best to go with the same size or a little higher in voltage, but i would not go down. so if 10v go with 10 or 16, but if 6.3 then go with 6.3 or 10, etc.
        as for the cleaning, I would wipe the area down with rubbing alcohol and let sit a bit to make sure it is completely dry before soldering the new caps in place. If you want to make sure everything is really clean then you could always wash the whole board, but that will take much longer.
        https://www.badcaps.net/forum/showth...ht=clean+board
        • Colt45ws
          • Jan 2009
          • 174
          Re: DFI NFII-Ultra
          Decapped. :P
          • Colt45ws
            • Jan 2009
            • 174
            Re: DFI NFII-Ultra
            New ones installed: (not in order)
            http://colt45.ws/misc/DFIIRECAPPED.JPG
            http://colt45.ws/misc/DFIIRECAPPED2.JPG
            http://colt45.ws/misc/DFIIRECAPPED3.JPG
            Ive never soldered on a PCB before, so it does not look that great, but they make a good connection. I tested each as I worked along. Some of the caps are crooked because I ran out of hands.
            Now I feel bad for not replacing the 1000s and 470s around the DDR and AGP slots. All these nice shiny caps for the cpu but cheapo Teapos and OSTs around there. Oh well, maybe next time.
            I probably wont be able to test it until Later tomorrow or Saturday. I have other things to do. Ill probably thrown this old Duron I have in it and pull the 100MHz jumper just to make sure it does not smoke the CPU for some reason. If it POSTs, Ill install my 3200+ then boot up a Gentoo Live CD. Ill pull the world and make file from my server and let it go on a emerge -e. With the test flag enabled it should catch problems.
            • kaniki
              • 514
              Re: DFI NFII-Ultra
              does not look too bad. I have definitely seen a lot worse. Some do look like they have a little bit too much solder on them, but then again it may be the pictures.
              • Colt45ws
                • Jan 2009
                • 174
                Re: DFI NFII-Ultra
                It runs! Muhahahaha!
                I did put a bit too much on them. I am a bit OCD, I think. "Hmm, thats not nearly enough." *tap* *tilt head* "More!" *tap* "..." *tap* *tap* "Okay, thats probably too much now."
                • kaniki
                  • 514
                  Re: DFI NFII-Ultra
                  i know that feeling.. what i usually do is if there is too much on it, i tap the soldering iron on the table to knock the excess solder off the tip, then just heat each joint one by one that need it while tapping the excess solder in between each one. the excess solder will be sucked onto the soldering iron. but hey, as long as it works.. good for you..
                  • Colt45ws
                    • Jan 2009
                    • 174
                    Re: DFI NFII-Ultra
                    Yes, Im very happy. I have an Athlon XP-M (Barton) running 12x200 atm.
                    • Colt45ws
                      • Jan 2009
                      • 174
                      Re: DFI NFII-Ultra
                      Did 120 hours of P95 TT at 12x200 1.8vcore. :P
                      • Colt45ws
                        • Jan 2009
                        • 174
                        Re: DFI NFII-Ultra
                        I finally did do the other ones.
                        I replaced all 8 1000uF 10V and 6.3V parts with Samxon GC 1000uF 6.3V
                        The two 470uF 6.3V parts got Samxon GD 560uF 6.3V.
                        • omega
                          Troubleshooting of redundant F750E-S0 Dell PowerEdge Server
                          by omega
                          Hello all,
                          as a beginner electronics hobbyist, after a few years I would like to place another post on this Forum section, given that I did not succeed in finding any useful advice among the other posts.
                          Over the last years, I have been using a PowerEdge Dell Server with two redundant PSUs, namely the 750W F750E-S0 ones (aka 06W2PW). Unfortunately, last summer one of them failed (perhaps owing to an overheating), and the server had for working to take into account the other one only. Of course I opened and tried to troubleshoot the failed PSU, but each cap I tested seemed to...
                          02-09-2024, 03:34 PM
                          HP ZBook 15v G5 Mobile server 15v Specification for Upgrade or Repair
                          This specification for the HP ZBook 15v G5 Mobile server can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15v G5 boardview and 15v G5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ZBook 15v...
                          09-06-2024, 11:39 AM
                        • harp
                          Comparing FreeNAS, FTP server, SMB server, multimedia server...
                          by harp
                          I thinking about some central LAN file server, on where I can put some files from other devices, or access to them, and maybe play some movie without download...
                          I never study this, but when I see that freenas need few gigabyte of ram to recommended working, some wiered partition, I wonder if I miss somewhat in the midletime...
                          Also exist "turnkey file server", and other turnkey products that I can not distinguished what is major difference and how it perform - no experiance at all.
                          What is general difference between this products, and what be most useful...
                          01-04-2024, 02:44 PM
                        • FALKLAN
                          Running Line Voltage and Integrating LED Pods - Automotive
                          by FALKLAN
                          Howdy everyone! I hope all is well where ever you are!
                          I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
                          I am uncertain how to convert this line into a switched 12v output line for the LED pods....
                          02-05-2025, 12:30 AM
                        • Fireballcz
                          Windows 2016 server L2TP/IPsec VPN - two subnets
                          by Fireballcz
                          Hello, please how to properly configure VPN in this environment?
                          I have two subnets in two different (geographical) workplaces, connected via IPsec (thru gateway routers)
                          Main subnet: 192.168.11.0/24, gateway (router IP) 192.168.11.1, Windows 2016 server (VPN, DHCP, DC etc.) 192.168.11.3
                          2nd subnet : 192.168.22.0/24, gateway (router IP) 192.168.22.1 - just client computers.
                          I need to allow external (home office) users connect via VPN server (192.168.11.3) to the 2nd subnet (192.168.22.0/24) to their computers (via RDP).
                          I have no problems with VPN connection...
                          07-29-2022, 03:20 AM
