MS-6590 KT4 Ultra - short on vcore
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Re: MS-6590 KT4 Ultra - short on vcore
    The link 'this thread' doesn't work. It goes to https://www.badcaps.net/forum/showthread.php?t=612720 but says No Thread Specified
    Follow me on YouTube
    Learn Electronics Repair
    • carlitosbala
      • Feb 2021
      • 23
      • Uruguay
      Sorry about that. the right link was https://www.badcaps.net/forum/showthread.php?t=38368, the ID I used was for a specific post within that thread.
      In any case, the initial advice I was given here was spot on, and I should have listened to it. As soon as I put a proper heatsink and fan on top of the CPU I got the motherboard to stay on. Live and learn...
      Unfortunately now I don't know if I have a working CPU to test. I got a second motherboard with the same socket, and of the 5 CPUs I have that should be compatible, only one works in the second motherboard but not in the KT4 Ultra, and 4 of them don't work on either. So either those weren't working in the first place, or they died at some point during testing.
      Anyhow, I'm parking this repair until I get a known good CPU and I get the eeprom programmer to check if the bios chip is good.
      Thanks for your help so far
        master hoarder
        • May 2008
        • 12175
        Can you post what CPU's you have and also what the 2nd motherboard is?
        A lot of early and mid-era socket 462 motherboards only had support for 133 MHz FSB CPUs - that is, Thoroughbred, at best. Barton CPUs were often only supported on the newer socket 462 motherboards that could do 166 & 200 MHz FSB. So check your CPU compatibility there. If the CPUs are known to be compatible with these boards, then at least they should have worked in the 2nd board, since you were able to get it working with one of the CPUs.
        • carlitosbala
          • Feb 2021
          • 23
          • Uruguay
          The second mobo is an M7VIG 400. Both this and the KT4 Ultra support 200, 266, and 333 MHz FSB CPUs according to their manuals
          The CPUs I have should be supported: the models are
          2 x SDA2200DUT3D (Sempron 2200+, Thoroughbred, 333 MHz FSB)
          3 x AX2000DMT3C (Athlon XP 2000+, Palomino, 266 MHz FSB).
          The one I got to work is one of the Semprons.
          I learned the hard way that the KT4 was actually doing the right thing by shutting down, the M7VIG happily fried (burned plastic smell included) three other CPUs I had when I turn it on without the heatsink, and even when I put the heatsink loosely on top of the CPU. You can't learn without breaking stuff, I suppose
          • adelfr2009
            HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
            by adelfr2009
            I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
            After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
            09-28-2025, 10:21 PM
          • playit
            450watt power supply 5v, 3.3v short to ground wire,in output rail ,connectors
            by playit
            hello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
            09-02-2023, 02:43 AM
          • Leefreeman97
            Diagnosing short to ground issue. pcb from an e scooter
            by Leefreeman97
            Hello, I have a pcb from an e scooter which had a faulty diode but even after removing it from circuit, it still has a short to ground on the three components circled. I have removed every cap on the board and tested one by one and the short is still there and all the caps test ok. Could this be because I haven’t put a diode back on it yet or where do I go next please?
            09-19-2025, 03:33 PM
          • MisterAIL
            820-00840 / No boot / PP3V3_G3H Short to ground
            by MisterAIL
            Firstly sorry for my english, french guy inside.
            I brought a macbook pro A1708 - 820-00840 logic board, wasn't powering on.
            History is a day, nothing happened when opening the laptop.
            Nothing special inside, no corrosion, no liquid damage, never opened.
            First, with the logicboard alone on the desk, mesures are :
            5v017 and 0.000 amp. nothing else.
            Finding a short on the PP3V3_G3H_VR, but not on the PP3V3_G3H (0.540 on diode mode), PPDCIN_G3H_CHGR_R present (5,1 volts) PPVIN_G3H_P3V3G3H around 4.1 volts. PM_EN_P3V3_G3H...
            10-13-2021, 11:42 AM
          • pavithra_uk
            Optiplex 3050 Vcore Mosfet short
            by pavithra_uk
            it is 3+2 vrm
            vcore high side mosfet (AON6380) shorted when turned on instatly killed the processor (i5 7400)
            gate drive chip (NCP81166) also gone.
            any suggestions before replace mosfet and gate drive chip? what if I replace 3 high side mosfets with more current capable mosfets?
            odd question:
            what if I put two silicone diodes series in forward way? assume each diode 0.7v drop and total of 1.4V. vcore not exceed this but can protect cpu from direct 12V hit from shorted mosfet ?...
            10-21-2025, 11:32 AM
