Jetway NU93B-2930 spurious reboots
  • theonetruestickman
    • Jan 2020
    Hey folks,
    I picked up a Jetway fanless box for cheap recently, but it won't stay running more than 10-15 minutes. As far as I can tell it's an older rev. of this box - I don't have the external antenna jacks:
    https://www.jetwaycomputer.com/JBC311U93.html
    https://cdn.badcaps-static.com/pdfs/...c0988f1417.pdf
    First thought was overheating but CPU temp wasn't really getting above 40C. There was a >0.5mm gap between the CPU die and heatsink, so now after shimming it the CPU stays around 25C on all cores and still has the reboot issue.
    I've swapped RAM out, removed the onboard MSATA drive, and removed the wifi card. This happens no matter if the machine is booted into an OS or is just sitting in BIOS - still reboots every few minutes.
    I've also tried multiple power supplies. It has a 9-24v input range, and the same behavior on a 12V AT supply I have on my workbench and a 16.5V IBM laptop adapter. Both should have adequate current capacity (>3A) for the board as far as I can tell and should have fairly clean power. (Caveat - haven't put my scope on the power lines yet. And don't have a digital scope that can trigger/capture.)
    I'm a bit at a loss as to where to start, beyond watching power rails. Anyone else seen similar issues or have experience with these boards? Don't see much for Jetway in the search.
    • Jan 2020
    Re: Jetway NU93B-2930 spurious reboots
    Welp, I'm an idiot - watchdog timer was enabled. *facepalm*
    Nothing to see here, move along...
    • repair-it
      Need advice testing a samsung power supply board with scope
      by repair-it
      I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
      07-12-2025, 11:00 AM
      Jetway 845LDA Motherboard Schematic
      Jetway 845LDAL is a motherboard based on the Intel 845GL (Brookdale-GL) chipset....
      11-05-2024, 12:10 PM
      Jetway 845GDM Motherboard Schematic
      Jetway 845GDML is a motherboard based on the Intel 845G (Brookdale-G) chipset....
      11-05-2024, 04:36 AM
    • EasyGoing1
      Reading input and output of bridge rectifier on the same scope?
      by EasyGoing1
      I have a 40 volt AC transformer that I put a bridge rectifier on, and I wanted to see the input signal and the output signal on the same screen on my scope, so I set one channel up with the test lead on one side of the input and the ground lead on the other side of the input, then I used another channel on the scope and clipped the test lead on the positive side of the output then the ground on the negative side of the output.
      When I connected the transformer to power, the wire that was connected between the ground lead on the second channel and the negative side of the bridge rectifier...
      06-26-2022, 12:52 AM
    • Track4207
      Hisense H50N5300UK reboots when showing full red images
      by Track4207
      Hi all! A bit of an interesting and unusual problem: as the the title suggests I have a Hisense H50N5300UK that reboots when showing fullscreen solid red images (and some other solid colours, but red generally causes the issue the fastest). I first came across the problem assuming it was an intermittent issue, but later lucked into finding out that a title sequence of a show I watch happened to trigger the reboot.
      What happens:
      • TV appears to operate normally, for an indefinite amount of time until a problem image appears
      • The problem image is displayed very briefly, then the
      08-30-2023, 11:58 AM
