Hi First post here but I´m an avid reader of these forums.
I´ve got an Supermicro X7DA8 board with 2x Xeon 5160´s - that´s been running unstable ever since I replaced the PSU (the old one blew) and I´ve been using Everest and Prime95 stability tests to stress the board. I´ve tested two separate PSU´s with the same results.
The symptoms are:
1. Board unstable after some running time - about 10 mins (no overheating issues/abnormal temps) - no errors when stressing directly after cold boot.
2. Errors only appear in Everest when stressing the cache.
3. Vcore voltage on CPU2 is lower then CPU1 (cpu1@1.3v - cpu2@1.1)
4. PSU voltages measure lower on this board then on a brand new ASUS board.
5. Most of the caps on this board are Sanyo SEPC 16v/330uf - 2.5v/820uf - and show no signs of stress/leakage.
6. I´ve tested all caps in-circut with an Peak ESR-70 and have found no apparent problems there.
7. Switching/Removing CPU´s has no effect.
8. Memory modules test fine in another board.
Does anyone have any pointers regarding this board/problem ?
The symptoms are:
