Need help to identify this component on the panel Mini-UWG
  • tckoo1411
    • Oct 2009
    • 24
    Hi everyone, I was doing spring cleaning and came across a little box. This is a wireless lan USB print server. Model planes Mini-UWG. One of the component is burnt and the markings on it is charred. I would like to replaced it to repair, but couldn't make out the marlings. Luckily there 1 component exactly the same on the logic board.it says
    Row 1 - 1550
    Row 2 - C069
    Row 3 - 7GC
    I searched the internet but couldn't find any leads to the manufacturer or replacements. Any help is appreciated. Thanks.
  • tckoo1411
    • Oct 2009
    • 24
    Re: Need help to identify this component on the panel Mini-UWG
    Let me use my desktop to post pictures in abiy
    • tckoo1411
      • Oct 2009
      • 24
      This is the one
      • SluggerB
        • Aug 2020
        • 747
        • US
        Which part is burned? Can you circle it?
        • R_J
          • 9605
          I can't find any information on the burnt ic, but the ADM5120 has a VDD of 1.8V and a DVDD of 3.3v so I suspect the two dfn8 ic's supply the two voltages
          • tckoo1411
            • Oct 2009
            • 24
            Hihi, Thanks for the reply. Was away for a long time. It was tucked away while I was trying to fix my ps3. In that case, can I ask you what ic should I use to replace the 2 dfn8 ic? Thanks a lot for your kind advice.
              • 21841
              Its an Analog Integrations Corp. AIC1550 ,the datasheet is attached
              • howardc64
                LG 49UJ6500 LCD panel lighter band that goes away
                by howardc64
                49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                02-19-2023, 12:13 AM
              • triplefour
                SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                by triplefour
                TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                tcon is built into mainboard.
                Only one cable goes to panel boards.
                there is a cable from one panel board to the other that links them.
                cost cutting measure that results in us having harder time to diagnose.
                removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                07-28-2022, 07:59 PM
              • Storyteller12
                QN55Q60R Service Menu Panel Help
                by Storyteller12
                I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                01-13-2024, 01:57 PM
              • maneatingmonkey
                Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                by maneatingmonkey
                I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                03-27-2024, 07:17 AM
              • howardc64
                Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                by howardc64
                • Prior owner tried a replacement main board. No difference.
                • Samsung 2x red blinking standby LED = panel fault
                • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                07-19-2025, 10:54 PM
