IT8718F replacement on GA-G31M-S2C
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Dear members,
    I have a GA-G31M-S2C mainboard with the IT8718F embedded controller.
    The mainboard does not turn on after pressing power button. the power button works fine and IT8718F is defective.
    how can I reprogram this IT8718F?
    If I replace this old IT8718F by another IT8718F taken from another used mainboard of different model, does the new IT8718F need reprogramming or resetting?
    Schematics:
    https://www.badcaps.net/forum/showthread.php?t=91437
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: IT8718F replacement on GA-G31M-S2C
    IT8718F doesn't have an internal Flash. On desktop boards it's very rare to have an EC with internal Flash.
    • caspian
      • Oct 2015
      • 1591
      • Laptop
      Thanks,
      According to the schematics, no external flash is connected to IT8718. The bios chip is only connected to ICH. Then, where is the EC firmware saved?
      • Mirenia
        Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
        by Mirenia
        I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
        I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
        In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
        The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
        03-30-2025, 06:47 AM
      • AustinComputerDoctor
        Sharp CC-60LE640U - after mainboard replacement, backlite turns on -- but cannot update firmware / see menu
        by AustinComputerDoctor
        I am looking / wondering if anyone knows where a good firmware download link is for a LC-60LE640U, the sharp support sight says the screen is archived but offers no links.
        I see backlite is active,
        but I cannot get the screen to return back to menus , etc
        This is all after replacing the mainboard...
        any assistance is greatly appreciated.
        03-25-2024, 12:43 PM
      • Ihandyrepair
        Change name on tv after mainboard replacement
        by Ihandyrepair
        HI guys
        just quick question,
        I just fixed a dead Sony 55x800h, I replaced with a 65x800h board
        now works everything seems ok
        except that after factory reset, it will show 65x800h on the name,
        screen is 55 inch now
        I am guessing the size of the tv is programmed on the main board right?
        I could just change the name only
        or any way to flash the chip to make it to be a 55x800h instead?
        thanks...
        07-04-2024, 11:37 PM
      • orcic
        MASTER TL240 and new mainboard LW36BKC01
        by orcic
        I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
        The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
        After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
        Now I have some doubts about how to connect the new mainboard to the old power supply.
        First of...
        05-12-2023, 08:10 AM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
