GX270 Substitute cap values?
  • fety
    • Jan 2007
    • 27
    This GX270 I have has 9 6.3v 1800uf 8x20mm caps all along the cpu and I have on hand a bunch of 6.3v 1500uf 8x20mm Rubycon MCZ caps. Will these work? or do I HAVE TO use 1800uf?
    I already plan on using them to replace the 1500uf 10x12.5mm ones around the ram slots.
    Let me know please, thanks!
  • fety
    • Jan 2007
    • 27
    Re: GX270 Substitute cap values?
    !!!!!!!!!! EDIT !!!!!!!!!
    OK hold up, I'm an idiot. I had my values all messed up.
    Correction:
    The ones along the cpu are 1800uf, I have on hand a bunch of 6.3v 1800uf 8x20mm Rubycon MCZ caps, can I use these to replace the five 6.3v 1500uf 10x12.5mm ones around the ram slots???? I've read I can use 10v 1500uf, but have all these 1800uf and would like to use them if I could.
    • etnietering
      • Apr 2009
      • 379
      Yeah that shouldn't be a problem, as long as the fact that they're physically taller won't cause issues.
      • proxneo
        Recapping Sony ICF-SW55 - verifying cap values
        by proxneo
        Dear reader
        I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
        At the moment, I have selected replacements based on the following list of values:
        3 x 470uF 10VDC
        3 x 4.7uF 35VDC
        4 x 47uF 50VDC
        8 x 22uF 6.3 VDC
        1 x 220uF 6.3VDC
        5 x 100uF 6.3VDC
        Which...
        06-21-2023, 12:38 AM
      • rashidjafar
        Nvidia GTS 250M Laptop graphics - Inductor and Capacitor values
        by rashidjafar
        I am looking for capacitor & Inductor values for my TOSHIBA Qosmio X500-110 - mobile graphics - Nvidia GTS 250M Laptop.
        Values for :-
        PC43 : Capacitor [3x1.5mm]
        PL7 : Inductor [2x1mm]
        PC39 : Capacitor [1x0.5mm]
        Any ideas would be appreciated.
        I can get Capacitor values from nearby components but wanted to know the max ratings also I dont have equipment to measure inductors....
        08-07-2025, 05:10 PM
      • Kobok
        Different (lower) resistor values on PCB?
        by Kobok
        Dear Alls,
        For sure it id a stupid question, but help me to understand. I am in a Dell 2007WFP revitalizing project - searching reason why not starting. Some resistors needed to replaced is is obvious. When I have soldered some resistors the measured (with multimeter) values were sometimes rather different written on them. I supposed these are wrong units so I desoldered and made a checking measurement and voilá the values is the same is written on. This happens only in case of a few resistors, most have the same values (+/- 10%) are written on it. "strange" SMD resistors =>103...
        09-19-2022, 07:30 AM
      • skdsp
        Need help identifying resistor values near BIOS chip on ASUS Zephyrus G14 GA402XV
        by skdsp
        I purchased a laptop that the previous user had tried to remove and replace a BIOS chip using a soldering iron not knowing that there is a ground pad under the 25R256JWEQ chip. In that process he damaged the BIOS chip and 3 of the resistors near the IO3, CLK, and IO0 pins. I have programmed a spare 25R256JWEQ chip using a CH341A programmer but not sure what values those resistors should be. If anyone has a boardview of this area and can provide those values that would be very useful for me.
        Attached is the photo.
        Thank you!
        09-27-2025, 09:05 PM
      • DeXXter
        HP VICTUS 16-d0500la Some Values
        by DeXXter
        Here some measurements on HP Victus 16-d0500la, it might help someone, the values are on diode mode->mV and some lower ones on Resistance->Ω.
        This specific laptop has an Intel i5 11400h + RTX 3050TI, the values are from a working laptop....
        03-13-2025, 03:16 AM
