Fuyjju Bad Caps
  • bugmenot
    Banned
    • Aug 2005
    • 10
    Fuyjju Bad Caps
    Hi, I found some bunk 1000uF 10V Fuyjju caps in my Flex ATX power supply. Sorry no photos... Leaking electrolyte, typical symptoms of intermittent system failure. Unfortunately I tweaked around too much before I realized it was the caps, now (after recapping) I get an intermittent buzzing that sounds like either a bad transformer or perhaps a blown transistor. However I still get power, it's just not sufficient voltage or it's unstable enough for the system to refuse to get past POST. I have no test equipment so I am shooting in the dark. Anybody have any ideas?
    Thx
    Bug
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Fuyjju Bad Caps
    you are not alone with the Fuhjyyu
    http://www.dslreports.com/forum/remark,14116577
    we had an old post with some crazy pics of Fuhjyyu fails also but were hosted offsite and got lost.
    there are a few guys here who can assist. hopefully they will pass by this weekend.
    • Chris1992
      • Apr 2005
      • 561
      Re: Fuyjju Bad Caps
      Wondered when this would come up - Antec use Fuhjyyu in their psus. However they don't make FlexATX to my knowledge... You're probably out of luck, bug. Hard to find FlexATX psus nowadays...
      The great capacitor showdown!
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Re: Fuyjju Bad Caps
        Just did a cap inspection on my Antec True 430 power supply approximately 10 minutes ago and the caps appeared to be OK.
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • Chris1992
          • Apr 2005
          • 561
          Re: Fuyjju Bad Caps
          How old is your True430?
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            Re: Fuyjju Bad Caps
            yeh i got several chieftecs (same as antec), all teapo etc no probs yet
            • RJARRRPCGP
              • Jul 2004
              • 6304
              Re: Fuyjju Bad Caps
              I purchased it on October 23, 2003.
              Arc A770 16 GB
              • Chris1992
                • Apr 2005
                • 561
                Re: Fuyjju Bad Caps
                Hmm. So Antec/Chieftec use both Teapo and Fuhjyyu.
                • willawake
                  Super Modulator
                  • Nov 2003
                  • 8457
                  • Greece
                  Re: Fuyjju Bad Caps
                  is anybody gonna reply to the original question?
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    Re: Fuyjju Bad Caps
                    the bad caps cause excessive ripple and noise that makes the system unstable.
                    a recap or replacement psu should fix it.the buzzing will be fixed too.it is due to the pwm chip seeing its own spikes from the reference on the output.
                    that is it samples usually +5 and if it is noisy the psu will hiss,fizz buzz,ect
                    • bugmenot
                      Banned
                      • Aug 2005
                      • 10
                      Re: Fuyjju Bad Caps
                      GREAT forum, thanks for the help. I forgot to mention I only replaced 2 out of 4 caps, which were the obviously bad caps (I guess the others could still be fried but not exhibiting symptoms). Problem was, the replacement caps are 3 times the size of the originals- this makes for some difficult squeezing things into the enclosure. Also some of the new caps are almost an inch off the board, however I did insulate the leads to prevent shorts. I figured if I blew a power transistor or transformer forget it, but if the buzzing could be fixed by recapping the other 2 I will definitely try that. I should have a report back in a few days if anybody is interested. I will submit a pic of the ridiculously stuffed enclosure...
                      Finally, my PSU is ACHME Flex ATX AM630BS20S
                      Also, looks like this character did exactly what I been trying to do:
                      http://forums.sudhian.com/messagevie...keyword1=achme
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        Re: Fuyjju Bad Caps
                        fwiw i get tons of swi prototrak heads in for overhaul.
                        the +5 +12 in the psu on the m2 has fujjiu caps.even if not vented they are always high esr.
                        easy to spot as you get artifacts when the logo comes sliding on startup or you select dro mode ,ect.
                        started seeing bad ones in pc psu's 5 years ago.
                          by momaka
                          03-12-2025, 03:42 PM
                        • eryjus
                          by eryjus
                          05-10-2023, 11:21 AM
                        • Paxman_Swede
                          by Paxman_Swede
                          Hello!
                          01-14-2025, 09:51 AM
                        • captain150
                          by captain150
                          03-16-2025, 07:34 PM
                        • Foetuss
                          Gigabyte GA-6OXT :: caps question
                          by Foetuss
                          Good evening
                          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                          But I was also suprised about the bigger boys, which are 330µF 25V.
                          Could it be they used 25V caps because they were cheaper / available at that time?...
                          02-11-2025, 12:22 PM
