No Power RX470 8GB - IR3553M
  • Acnologia
    • Dec 2016
    • 421
    • Poland
    Hello to all.
    My personal card, has suddenly died, i was helping for 1 week to folding@home , when the COVID-19 occured. And suddenly it didn't get any power.
    My PSU Titanium grade, and is connected to powerline with UPS.
    So the :voltage: is everytime safe and good.
    Now, i have tested via youtube,that saw some videos from RX470/480 dieing on spot ,that the chip IR3553M is making a connection to ground and dies and takes the Dual fuses,with it.
    I have taken some photos and i am attaching them here to get help from you guys,if you can help me out.
    Indicators.
    Replaced the dual fuse , top right corner (2X 10 A)
    Replaced the bottom IR3553M which had conntected to ground.
    As i saw the 1,2 points in the IR3553M (that i have in the top photo) , 2 should not beep ,and number 1 should beep (solder point) .
    All the IR3553M now, remain silent on leg 2 , and on leg 1 beep.
    I don't see any other faults, but the card still remains cold as dead.
    Any suggestions ?
    Here are extra links for high resolution photo :
    https://imgur.com/a/hAL65R7
    Thank you.
  • Acnologia
    • Dec 2016
    • 421
    • Poland
    Re: No Power RX470 8GB - IR3553M
    My mistake.
    I found the problem. Hahaha , silly of my self.
    I compared the picture of my RX470 with another RX470 and i saw that i didn't put another Fuse 10A ,bottom left side of the "DVI" connector ,it has a 10A fuse that i had removed it ,and didn't remember it.
    Now,it posts good
    • Acnologia
      • Dec 2016
      • 421
      • Poland
      Okay , now new problem.
      Yesterday the card, went by the diagnostics, even Heaven Unique for about 30 minutes,and then i played like 2 hours of Warzone, with max settings.
      The card was normally hot,as usual , and the airflow of the system good as always.
      It suddenly died again.
      I tested today all the other 4x IR3553M all shorted. The bottom fuse as well , it beeps only when you take it out,when you place it on board it doesn't beep.
      I changed and replaced the IR3553M with a new Fuse as well ,and the card still remains dead.
      I see there is 2 x capacitors missing from the IR3553M in line, 2 x really small ones. Can you or someone figure out, why this is happening and how can i measure what capacitor should i use ?
      The picture i attach shows the 2 capacitors,that are missing today.When yesterday they were on place.
      • Acnologia
        • Dec 2016
        • 421
        • Poland
        I measured another capacitor from above,in the same place with target meter at 200nF, showed me 123nF , so the capacitor is 123nF ? Right ?
        • ziko07
          • Jun 2021
          • 99
          • Somewhere
          You still have this card?
          Tnx
          • Acnologia
            • Dec 2016
            • 421
            • Poland
            Tnx
            Yes.
            • ziko07
              • Jun 2021
              • 99
              • Somewhere
              Can you please check for me is those 4 pins connected to GND?
              And did you solved your card?
              Tnx
              • Acnologia
                • Dec 2016
                • 421
                • Poland
                Tnx
                No i cannot, i don't have it anymore.
                Yes, i had it fixed with my changes.
                • Bluedog69
                  • Nov 2021
                  • 11
                  I have almost the same problem as you,
                  Can someone give me an eBay link to the 5KW20 270 16V capacitor,
                  Thanks,
                  Did you fix your card ?
                  • Acnologia
                    • Dec 2016
                    • 421
                    • Poland
                    Thanks,
                    Why is the same question again ?
                    Why doesn't anyone read the thread?
                    • fab13
                      • Dec 2021
                      • 109
                      • France
                      Thanks,
                      I have a RX480 8GB
                      I just read your messages and I have a problem also at the same level no voltage at +VDDC and mosfet IR3550 on +CIN and at 0mV in diode mode and almost 0Ohm
                      Any idea?
                      It would be with joy to help if needed too.
                      • corrize
                        A funny fuse story – Lumix LX100 II
                        by corrize
                        Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                        I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                        The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                        There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                        And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                        10-19-2023, 09:58 AM
                      • jesterace
                        Samsung UE46ES8000 Blown fuse but no other signs of short
                        by jesterace
                        Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                        09-11-2024, 03:14 PM
                      • jshhh
                        Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                        by jshhh
                        Hi guys,
                        I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                        How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                        Anybody know how to remove this type of fuse?
                        (The fuse is toward the bottom of the image labeled F2)...
                        06-17-2025, 01:35 AM
                      • Babbar
                        by Babbar
                        04-12-2024, 01:12 AM
                      • drykid
                        Matsui 175S microwave fuse replacement
                        by drykid
                        I recently picked up a used Matsui 175S microwave that was powering up (starts, turntable rotates) but not heating. From looking online the most likely culprit was the fuse, but unfortunately in this one the fuse had heated up and fused with the (badly designed) fuse holder and couldn't be removed. I guess this might indicate further issues beyond the fuse itself but at this stage I just want to replace the fuse and see how I go from there.
                        Anyway since I couldn't get out the fuse itself the easiest fix was to replace the fuse holder assembly that runs between the...
                        12-21-2020, 01:15 PM
