XFX 630i (MG-63MI-7109) Fails to power up
  • Mad Professor
    • 9
    Good Day All.
    I have a XFX 630i (MG-63MI-7109) that fails to power up.
    I am testing this board with good known working PSU, CPU, Memory, ect.
    With eveything connected, when you press the power button eveything powers up for a split second, and the PSU led go's from green to red.
    If I discount the 4pin CPU power connection, and press the power button the system fires up, but there is no post.
    With eveything disconected, I used my Digital Volt Meter to test the 4pin CPU power connection, and it's a dead short.
    There are not poped caps or burnt parts.
    As it is quite hard to test mosfet's in circuit, I desided to remove all 9 of the CPU mosfet's.
    Once I removed all the mosfet's I retested the CPU power connection, and the dead short is no more.
    So one or more of the 9 mosfet's had got dead short.
    I am trying to find the full datasheets for the mosfet's so I can get somthing that is compatible.
    So far this is what I have been able to find out about the mosfet's.
    http://products.niko-sem.com/index_e...od_list&cat=24
    Part Number: P70N02LDG
    Package: TO-252
    Configuration: Single
    Type: N
    VDS (V): 25V
    VGS (±V): 20V
    VGS(th) max: 3V
    ID (A): 65A
    RDS(on) mO max @ 4.5v: 15
    RDS(on) mO max @ 10v: 8.5
    Ciss typ.(pf): 1200
    Crss typ.(pf): 350
    Qg typ.(nC): 25
    Qgd typ.(nC): 10
    Part Number: P0903BDG
    Package: TO-252
    Type: N
    VDS (V): 25V
    VGS (±V): 20V
    VGS(th) max: 3V
    ID (A): 50A
    RDS(on) mO max @ 4.5v: 16
    RDS(on) mO max @ 10v: 9.5
    Ciss typ.(pf): 1200
    Crss typ.(pf): 350
    Qg typ.(nC): 25
    Qgd typ.(nC): 10
    There are also four caps near the mosfet's, and they are Sanyo 1000uf 16v, I am going to replace them as well.
    Thanks for your time.
    Best Regards.
  • BlackScreen_22
    Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
    by BlackScreen_22
    Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
    Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
    I had no problems connecting mosfets and capacitors,...
    08-27-2024, 12:46 PM
  • kotel studios
    Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
    by kotel studios
    Finally got time to fix this board up.
    At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
    Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
    04-22-2025, 05:08 AM
  • flerre
    Gainward Phantom GTX 980 - mosfets w/ integrated driver NCP5369
    by flerre
    Hi!
    Managed to get a Gainward Phantom GTX 980 in an auction for a bin with components.
    No video out so I started fault finding and found a blown fuse for 3 mosfets. Started checking for shorts and found what I think is a short through all of those 3 mosfets; 0.1 ohms between "VIN" input and "VSWH" output. All mosfets in this gpu are the same ones (NCP5369) with integrated drivers and when I tried measuring the other ones through these ports they were somewhere in the kilo-ohms range.
    So, could I safely assume all of these 3 mosfets are...
    03-13-2022, 12:14 PM
  • DrDos
    kenwood kr-6030 Mosfets?????
    by DrDos
    Hello everyone, I have decided to try and replace the mosfets in my power amp (the one with relay and left and right sides) on my kenwood kr-6030. I'm trying to get the A side of my speakers working. I have replaced all the caps in the power board and I thought why not change the mosfets. They seem to be working since I have great music coming out of the B side speakers and since I am not an electronic guru (but I am learning) I don't want to make any mistakes. The mosfets I have are listed A913 so I guess 2sa913 and 2sc1913. Can't really find those in mouser or digikey at least with the info...
    09-20-2025, 04:42 PM
  • JoelJ
    Ampeg PF-350 bass amplifier head repair
    by JoelJ
    Hello everyone!
    I recently bought a broken Ampeg Portaflex PF-350 bass amplifier head in unknown condition. As it turns out, it's completely dead. Tried powering it on with the dim bulb tester, dead short.
    I have attached the schematic below.
    What I found:
    TH1 is cracked visibly but measures 6 ohms. Will replace it but should be okay for testing for now.
    Either Q1 or Q2 was dead shorted. Don't remember which one but one of them. Both are FQPF12N60C. I replaced both with SiHP18N50C to test as I had these on hand. They are the same package, pinout, mosfet type....
    09-09-2025, 08:37 AM
