Imac a1225 no power
  • herbostyle
    • Mar 2016
    • spain
    Imac a1225 no power
    Hi. I need help with an imac a1225. I have the 4 lights on the board but the fan does not work, nor does it give video on the screen. Does nothing. If someone can provide me with the bios of this team, it would help me. Thank you
  • mon2
    • Dec 2019
    • 14657
    Re: Imac a1225 no power
    Hi. If you are still trying to repair this computer, power down and remove the display wiring. This means remove the LVDS cable (carefully - has the latch); the thermal sensor wire; the backlight power supply cable harness.
    Be very careful to NOT touch any of the power supply areas which are exposed and can be lethal and are a shock hazard.
    Even better to unplug, attempt to turn on the power button to drain the power supply and/or let it sit for a few hours before attempting the above.
    Then power on without the display.
    Now the iMAC should sense the loss of the thermal sensor and kick on the fans.
    Do the fans kick into hyper mode? It did for our A1312 chassis.
    The 4 lights ON is a very good sign but without the display, you will see only 3 lights ON. The last light = LCD display not communicating with the video card and that is to be expected since the display is removed.
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
    • WVUfan
      PS5 EDM-033 One Beep,No Lights, No Power Troubleshooting Help
      by WVUfan
      hello. i've a ps5 edm-033 mobo w/ no power, lights, but one beep when power pressed. i've hooked to uArt and only error code is 80871001 (DDR4 No Power or Short Circuit). i have a donor board, same model, that does power up, fan spins, blue light, and beeps 3 times, then powers off. it has a botched HDMI port replacement job. so w/ the board i'm interested in, with the error 80871001, i was able to research and obtain voltages of the SSD PMIC. i've attached pictures of the provided diagram by DylanBBK (@d62 on Discord) and my voltages and picture of my board. my question is on my picture...
      08-11-2025, 01:12 PM
      by sam_sam_sam
      03-31-2024, 02:12 PM
