Hi. I need help with an imac a1225. I have the 4 lights on the board but the fan does not work, nor does it give video on the screen. Does nothing. If someone can provide me with the bios of this team, it would help me. Thank you
Imac a1225 no power
Tags: None
Re: Imac a1225 no power
Hi. If you are still trying to repair this computer, power down and remove the display wiring. This means remove the LVDS cable (carefully - has the latch); the thermal sensor wire; the backlight power supply cable harness.
Be very careful to NOT touch any of the power supply areas which are exposed and can be lethal and are a shock hazard.
Even better to unplug, attempt to turn on the power button to drain the power supply and/or let it sit for a few hours before attempting the above.
Then power on without the display.
Now the iMAC should sense the loss of the thermal sensor and kick on the fans.
Do the fans kick into hyper mode? It did for our A1312 chassis.
The 4 lights ON is a very good sign but without the display, you will see only 3 lights ON. The last light = LCD display not communicating with the video card and that is to be expected since the display is removed.
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by WVUfanhello. i've a ps5 edm-033 mobo w/ no power, lights, but one beep when power pressed. i've hooked to uArt and only error code is 80871001 (DDR4 No Power or Short Circuit). i have a donor board, same model, that does power up, fan spins, blue light, and beeps 3 times, then powers off. it has a botched HDMI port replacement job. so w/ the board i'm interested in, with the error 80871001, i was able to research and obtain voltages of the SSD PMIC. i've attached pictures of the provided diagram by DylanBBK (@d62 on Discord) and my voltages and picture of my board. my question is on my picture...
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... - Loading...
