Abit BP6 with bad coils
  • Warbird
    • Jul 2005
    Hello
    I've got an Abit BP6 mainboard.
    The bad caps have been replaced (I've replaced all caps, even those one, which seem to look okay)
    The problem is, that there's a coil on position C17 which looks burned. I also want to replace it, but I don't know, where I can get it.
    Can anybody tell me, where I can get such a coil ?
    It has 7 windings.
    Kind regards
    Patrick
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Re: Abit BP6 with bad coils
    If you can find a scrap BP6, thats your best bet. If not, get some wire the same gauge and rewind them by hand. Unwind the old wire and cut the new wire the same length as the old wire.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • bushytails
      Moderator
      • Dec 2004
      • 217
      and make sure your VRMs aren't toasted. might have been a good idea to check before recapping, if you're not into replacing lots of parts, or the possibility of the northbridge and other fun things being fried. and when testing, don't put in a CPU you'd like to ever use again.
      --Randy
      • Warbird
        • Jul 2005
        Thanks for your reply. The problem is that the metalic core of the coil is burned and splintered.
        I have an electronic store here in my city, but I do not know, which information they need, so that I would get the same or a similar metalic core, so that I could handicraft a "new" coil.
        Any idea ?
        • AK0R
          • Mar 2005
          • 204
          Any idea ?
          Have you tried contacting Abit Technical Support? You already know which component number, and how many turns on the coil. You'll need someone with detailed technical knowledge of the board.
          • PeteS in CA
            • Aug 2005
            • 3586
            • USA, Unsure of Planet
            You need to find out what the core is - mfr, P/N, and crossovers. There are several different technologies that the core could be (e.g. powdered iron, metglas, Kool-Mu (tm of Magnetics Inc.), molypermalloy powder). You need the right type to get the proper inductance and core loss characteristic. Avoid using an el cheapo core, it could destroy itself, the caps, and more.
            PeteS in CA
            • Warbird
              • Jul 2005
              Yes, I've contacted abit.
              They told me, that they do not have any replacement parts and that they can't give me any specification info of the faulty component, since this mainboard is too old and they do not have any longer the spec papers. (very surprising)
              • u666sa
                HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                by u666sa
                Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                Platform: ipa32 la-m024p rev 1b
                Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                I found a short on the other side:
                10-04-2025, 05:03 PM
              • artasdmc
                MSI 3070 Ti Suprim short on 12V left 8 pin, and short on 5V.
                by artasdmc
                Hi, I've got a 3070 ti that used to work for a limited time, my friend bought it expecting it to be a thermal/psu issue, but alas it is not. It died completely and it shorted out two rails on its way out. It blew a fuse on the left connector, but for testing purposes I've just used a 20a wire fuse to connect it back.
                I think the core should be fine as PEX coil is reading about 9 ohms.
                These are the two coils that are showing a short. I do have a thermal camera, so I injected 1v/0.9a at the 5V coil and the orange dot is where it heats up (it's a capacitor). When I inject the...
                11-17-2025, 06:09 AM
              • adelfr2009
                HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
                by adelfr2009
                I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
                After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
                09-28-2025, 10:21 PM
              • wnlewis
                New wire for my RDE3340 Whirlpool electric range
                by wnlewis
                OK. I got the rocker switch figured out thanks to the good advice on this forum.
                Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                This is a Whirlpool RDE3340 electric range.
                The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                Where may I find parts...
                01-08-2025, 11:21 PM
              • Rik vb
                Power issues with HP pavillion 15 eh1815nd
                by Rik vb
                I have some issues with my HP pavillion 15 eh1815nd.
                It doesn't wanna power on anymore, when i click the start button it briefly turns white, then the light goes off again.
                The charge light is indicating that it's charging when i plug it in.
                I did some tests accross the board, and found 2 (coils?) near the CPU, one of the small (chips?) next to the bottom coil seems to get unusually hot, and the coil shows quite a lower resistance then the coil above.
                Most/all capacitors next to, and below the bottom coil seem to be connected to ground on both...
                09-08-2024, 01:09 PM
