EVGA 133-k8-NF43-XX blown FX caps
  • Keith41501
    • Nov 2009
    • 10
    Within a space of about 2-3 weeks I kept hearing a loud "POP"noise come from the room my PC is in. I didnt have any idea what it was thought maybe the TV or power strip things were plugged into. Then I looked into my PC case with a flashlight and noticed all 5 of the FZ 6.3V caps were blown and 1 of the 10V caps was swelled up. Now I know what that noise was hehe. Anyway I ordered replacement Rubycon caps from this site, enough to replace all the FZ caps. I can't wait , this has been a really good mobo.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: EVGA 133-k8-NF43-XX blown FX caps
    I see in the other threads that you've discovered the 'joys of FZ' aren't uncommon at all.
    Let us know how the repair goes.
    Mann-Made Global Warming.
    - Dr Seuss
      EVGA e-GeForce 7600 GS AGP 256MD2 [256-A8-N542-T2] with bad caps - fixed
      by momaka
      I did it again – I had to fulfill my inner desire to fix yet another old piece of hardware. This one is actually kind of worthwhile, too – it’s an EVGA e-GeForce 7600 GS AGP video card, model P/N: 256-A8-N542-T2. With the popularity of “retro” PCs from the Win9x to XP era going up, and the diminishing supply of decent AGP cards, it is expected their prices will go up. Or is it? I bought the this video card rather on the cheap side (~$9 USD shipped to my door), because the eBay seller listed it for parts or repair (and correctly noted the bad capacitors.)
      So, here is the...
      06-06-2020, 04:39 PM
    • odtech
      Asus UX490U laptop blown (caps?) on power board.
      by odtech
      Greetings friends.
      I was given this nice little laptop and would like to revive it if possible but i'm stuck identifying blown components. I'm very new to the repair game so i'm proceeding very cautiously.
      I don't know the history of this laptop and the donator didn't elaborate what happened but it seems some moisture got into the USB C charge port and the result was what looks like some blown caps. The tell is some gunk inside the USB C port and corrosion on the outside as well as what looks like corrosion around the blown components.
      Any guidance...
      08-06-2023, 10:29 AM
    • zlr8r
      HP Probook 640 G5 - replaced blown components, getting power led, fan full, 5-flashes on CAPS Lock and NUM lock, black screen
      by zlr8r
      Hey guys, bit stumped with this laptop after replacing 2 blown components i.e., MP86493, MP2979A.
      To begin with, this laptop was dead-dead.
      Now with replaced (visibly) blown components, i do get some progress; after connecting battery or main cable;
      • am getting white power led
      • 5-long-flashes on CAPS Lock and NUM lock
      • then, fan full speed
      • CPU heats up some (smaller die PCH, does not)
      • always constant black screen no matter what's tried
      • no USB recognition
      • no HDMI output
      this is as far as I can get with it and not sure where to inspect next ?
      I tried...
      03-27-2024, 03:13 PM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • ReparaPC
      EVGA RTX 2070 Super Black with u610 blown up
      by ReparaPC
      I have an RTX 2070 Super from evga with a blown up IC. With the IC on the card, pin 17 had a short to ground. This pin is connected to the 5V rail by R993, a 0hm resistor. I removed both U610 and R993, to discover that the 5V rail has 800 Ohms of resistance to ground. After checking some resources online, i found a picture which describes the usual measurements a Turing series GPU should have in order to "work properlly". Interestingly enough, this gpu doesn't have U31, the IC responsible for the creation of the 5V on the card, as well as no L47.
      Are these 800 ohms rigth...
      05-08-2024, 03:10 PM
