Software to analyze Video RAM faults on graphics cards?
This is a sticky topic.
  • Traptor
    • Nov 2021
    • 111
    • Magyarország
    #141
    Hi guys,
    anybody knows how can I test vega 56 card memory?
    I have The Lord Of The GPU package but this contain only vega64 test.
    • bajno
      • May 2017
      • 27
      #142
      Originally posted by benwaterson
      Re: Software to analyze Video RAM faults on graphics cards?
      Newer MATS in here 520.112
      https://drive.google.com/drive/folde...14UC6rNCE18xBt
      Can you share it again? Link is no longer active.
      • Aliencomputres
        • Aug 2019
        • 195
        • România
        #143
        Hello Dicky96 , did u ever solved your problem ? Im running into exactly the same problem u have/had . Kind regards
        hello,
        3.part4.rar not work.
        • Shamsi
          • Oct 2015
          • 31
          • india
          #144
          Link not found.Error showing
          • dude23
            • Jul 2025
            • germany
            #145
            123
            • Hakuu
              by Hakuu
              Hi There,
              More Details
              TV Model - LG OLED77G1PUA
              07-12-2023, 02:37 PM
              GeForce RTX2080 Super Aero video gaming card issues help need
              This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
              Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
              05-07-2023, 08:12 AM
            • chth96
              How Can I test PWM DM0365R?
              by chth96
              Hello
              I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
              So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
              I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
              I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
              06-18-2025, 04:14 PM
            • japlytic
              Gigabyte Z690 UD AX DDR4 distingusihing failures+default video
              by japlytic
              On this motherboard with a CPU (requiring discrete graphics) supported by the BIOS (version F3) and a new video card, it has a beep code indicating a CPU failure while the onboard diagnostic LEDs indicate a video system failure and using a different motherboard of the same model had the same result despite confiriming that the new video card along with the power supply as well as the connected display/cable was operational in another system.
              So therefore, I've found that the Video diagnostic LED illuminated before CPU diagnostics were performed and since the CPU has failed, video diagnostics...
              12-30-2022, 11:12 PM
            • myth77
              sharing repaired video card faults in photographs
              by myth77
              I am having a big problem in how to recognize gpu fault or vram fault on laptops or desktops when picture is partially broken or with artifacts or....Sure, i measure resistance and trying to conclude what is a bad part but it is very time consuming so i emaganed this thread for the people to share pictures of repaired video cards... what was the bad picture before? and when they repaired it, was it a vram fault or gpu chip fault...I think that it would help other members a lot (sure would help to me).
              I have found only a few threads on the internet (but very old) that are describing what...
              09-27-2021, 09:30 AM
