Ecs-h61h2-m6 ver1.0
  • godfrey7
    • Apr 2020
    • 12
    • india
    Ecs-h61h2-m6 ver1.0
    Dear friends,
    every time i put time & date in ecs-h61h2-m6 ver1.0.i have changed the cmos batt and bios firmware,how to solve.please reply.
    Thanks in advance
  • paul-o
    • Oct 2018
    • Brazil
    Re: Ecs-h61h2-m6 ver1.0
    Maybe the battery connector is covered with oxidation and makes bad connection.
    You have to find the V_BAT on the super io chip and trace it back to the battery.
    • questore
      XPS 13 9370 CMOS battery voltage always low
      by questore
      Hi Everyone,
      I have brought you a mistery item
      This laptop have come with some strange faults.
      1. CMOS battery was flat 0v
      Symptoms:
      - After using the laptop and shutting down and removing the AC adapter for at least 1 minute, the laptop never turned on until EC reset (either shorting RTC or removing battery and long pressing power button)
      Amp drawing was stuck at 0.005 milliamps.
      - Laptop cannot really be turned off because it autostarts about 5 sec-1 or 2 minute. (lid sw is not the problem)
      After inverstigation RTCD1 diode had a low value...
      09-30-2025, 05:47 AM
    • titomno2
      Gaming Laptop Zephyrus S17 TFT not detected every time !
      by titomno2
      Hi guys,
      I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
      So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
      On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
      Then the screen won't work for a long period of time.
      If I wait 1 or 2 hours it work again most of the time.
      When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated...
      01-19-2025, 08:27 AM
    • flat-earther
      Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
      by flat-earther
      I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
      To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
      I have opened the camera and I think there is enough room to add something inside to accomplish this:
      The camera is powered by a 3.7V nominal single cell lithium ion battery.
      So I need to connect another battery in...
      06-08-2025, 02:00 AM
    • questore
      HP Omen 17t-w200 WHAE error when charger connected
      by questore
      Hi Everyone,
      I faced a strange issue of my friends laptop.
      You might have an idea because I'm out of my deept here.
      The laptop starts every time no problem.
      - When The original 230W charger is plugged in (with or without the battery same) and I start installing windows or start a preinstalled windows, then WHEA error happens or black screen freeze.
      - When I start laptop with only battery then windows installer start fine, install goes nice and fast. After installation I have to disable the nvidia 1070 and start windows this way and then enable the Nvidia 1070...
      06-05-2023, 01:20 PM
    • OscarAV
      HP Pavilion dm4-1065dx long time to get the power led on
      by OscarAV
      I just came here to see if someone has had the same problem I have, and if he or she solved It, to know how to do It.
      I have made a quick search for my laptop but I have not seen anything similar.
      I have an old laptop, an HP Pavilion dm4-1065dx which takes a lot of time to be ready to start if the laptop has been unplugged for a while. It has no battery. The battery failed long time ago. It needs to be plugged to work. But as I said, It can take a lot of time until the charging led gets on, and I can switch on the laptop. I am using an external monitor...
      09-23-2024, 05:53 PM
