Help asrock fm2a55m- vg3 missing 3.3v on ram
  • christian0024
    • Apr 2016
    • 25
    • philippine
    Always beeping ram problem
    How can jumper the 3.3volts
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Re: Help asrock fm2a55m- vg3 missing 3.3v on ram
    That motherboard is DDR3 so Vram is 1.5V not 3.3V
    There will be a VRM that generates Vram from some other supply, 5V, 3V or 12V
    You need to find that supply, it will probably be near the RAM slots
    If you cant' find the source of Vram just by lookihng, you can look up the pinout for DDR 3 sockets and trace it from there or you could trace it from the capacitors on DIMMs.
    Bear in mind some of the capacitors on the DIMM will be connected to Vref (0.75V) not Vram and one end of all capacitors will go to ground. You could have a short on Vram to ground also
    Rich
    Follow me on YouTube
    Learn Electronics Repair
    • piernov
      • Jan 2016
      • 4439
      • France
      There's still a 3.3V power rail going to the RAM to power the I2C ROM for SPD, but it should be directly connected to the main 3V rail.
      • dicky96
        Sun Seeker
        • Mar 2017
        • 1825
        • Spain
        This should help
        Asrock FM3A55M Boardview
        • kotel studios
          Asrock 970 PRO3 - missing 1.1V on NorthBridge
          by kotel studios
          Recently I got this Asrock 970 PRO3 board from scrap. It had a few missing caps under the NB which I've replaced. Sadly, one of them went short (NC597 from boardview file). I did replace it and there doesn't seem to be any shorts left, but the board is not executing POST nor beep codes. I once got it to POST after I was slightly bending it, but that was only once. I tried to redo the same steps but to no avail. All caps on the backside of NB have 22-ish ohms.
          I have traced the problem to an dead Northbridge VRM. There's no voltage on Phase (pin 8), FB (pin 6), UGATE...
          08-02-2025, 02:34 AM
        • gabrieljma1
          Request: Full BIOS dump for ASRock Z790-CX (DDR5)
          by gabrieljma1
          I’m looking for a full raw 16 MB BIOS dump for an ASRock Z790-CX (DDR5) motherboard.
          The board powers on (fans spin, RGB lights on, RAM LEDs active), but there is no display output and the VGA and BOOT LEDs stay lit.
          I’m using an Intel i9-14900KF CPU (14th gen), and it seems the BIOS version on my board doesn’t support it yet. I tried to flash the official ASRock BIOS file (renamed .ROM → .BIN) directly using my RT809H programmer, but it didn’t work — monitor stays on but with black screen, so I believe the ASRock update file is not a complete...
          10-08-2025, 03:32 PM
        • ugamazing
          820-02020 PPBUS_AON missing
          by ugamazing
          Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
          Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
          02-05-2025, 04:21 PM
        • jpreza
          Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
          by jpreza
          I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
          Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
          It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
          Looking at the card, it appears to be missing the following:
          1x 1.0uH inductor - orange square
          2x...
          11-01-2024, 10:54 PM
        • mouuse25
          Asrock Z390 Taichi, missing chip
          by mouuse25
          Hello, I need help figuring out what chip came unattached from my motherboard (Asrock Z390 Taichi). I found a picture online of the chip. However I cannot find a boardview or a high resolution picture to identify what it was.
          My assumption is that it is a buffer logic 74LVC1G125GW. judging by a Z270 Taichi boardview I found but not really a fan of smoke testing parts.
          Any and all help is appreciated - Thanks
          03-24-2022, 08:17 PM
