94V-0 E307069 GE-1 (HM65) there is vcore but no
  • Tankado
    • Mar 2015
    • 15
    • Turkey
    There are two of this card. One works well, and I measure it to fix the faulty one, and the other. The problem is as follows; The card turns off when the current reaches 1.2 A, installing and starting the processor on the card. I get all the voltages without a processor installed. VCore 1.05, GCore 1.1 and other voltages of 5 V, 1.8 V and 3.3 V are available. There is no faulty mosfet, no heated voltage regulator. I removed all the tantalum and aluminum capacitors from the work card and attached it to the faulty card. Nothing has changed. When I insert the CPU, the PGOOD ISL95870 output drops to 0, then the VON ISL95835 signal drops to 0 and interrupts the strobe signals 95835 and 95870. The processor is not faulty because it is running on a different board. Also, I programmed BIOS many times with the same firmware model. I even copied it from work cards. The NTC and GNTC (gcore) resistors of the solid card and the faulty card are the same. There is no short circuit on the board smd capacitor, I checked them all. When the board rises above 1.2 A, it fails for 1-2 seconds and turns off the VCORE voltage. GCore remains available. Durable card pulls up to 3A at 12v. However, this card for some reason shuts off energy when it rises above 1.2A. I don’t know what to do. Since I don’t have an oscilloscope in which it is stored, I cannot observe the change until the energy is turned off. As a last resort, I will try to transfer all smd Vcore capacitors from a solid board to a failed board, although there is no short circuit capacitor. But before I try, I still want to know your opinion. Perhaps there is a simple malfunction, but I could not do this and tried to fix this card for several days. By the way, this card is an OPS (Open Pluggable Standard) card, it is not mainly different from a laptop, and it is an Intel i3 system based on HM65.
  • Tankado
    • Mar 2015
    • 15
    • Turkey
    Re: 94V-0 E307069 GE-1 (HM65) there is vcore but no
    Maybe I explained the problem a little confused.
    There are all voltages with no CPU installed. When I insert the CPU, the card draws 1.2A,
    then the vcore regulator turns itself off. I took all the capacitors from a working card and put them on.
    The CPU runs on another card, so the CPU is intact.
    There is a problem that shuts down the regulator when consumption goes over 1.2 amps.
    • Tankado
      • Mar 2015
      • 15
      • Turkey
      Any help?
      • kropotkin
        Oscilloscoopper
        • May 2018
        • 52
        • Republic of Belarus
        At sympthoms it is similar to dead HM65. Try to compare resistance from ground at voltage rails on both boards (working and broken), e.g. 1.05v, 3.3v, 5v, vcore. CPU must be removed.
        • el panke
          • May 2019
          • 78
          • argentina
          plz post ur bios backup, i need it )
            • 21844
            Desktop PC bios requests go here: https://www.badcaps.net/forum/forumdisplay.php?f=15
            What is the PC model,are the any part numbers on the motherboard,or stickers ?
            • soumya199929
              • Apr 2022
              • 65
              • India
              Try changing ISL chip and mosfet driver ic.
              • alpersen
                Modding, adding usb/c audio pcb to laptop with faulty sound card/chip, Lenovo L340
                by alpersen
                Hello
                After months of trying I gave up my laptops sound card. I plan to solder a sound card on pcb inside my laptops case, probably connecting to usb ports inside. Do anyone has an experience to recommend pcb type audio/sound card suitable installing inside a laptop? Probably should have some type of amplifier for connecting to internal speakers ( speakers ).
                Thank you
                11-19-2023, 09:34 AM
              • Thetechdude
                Repair help. Zotac trinity 4070ti 12G 3x
                by Thetechdude
                Hi Guys.
                Here I have a 4070ti with some issues.
                When powered on the led lights which power on (where the zotac logo is) flash green 3 times. Once it has flashed green 3 times it does not post.
                Just to mention I have not worked on many 40x cards before therefore some of my assumptions could be wrong. If you do happen to find that my analysis is wrong or I have missed something feel free to comment.
                Additionally, I do not have a schematic for this exact card model so if anyone is willing to post the schematic it would be much appreciated.
                Resistances:...
                09-07-2025, 07:49 AM
              • Christos Tsiligiannis
                Marian Trace Alpha sound card repair help
                by Christos Tsiligiannis
                Hello to the forum.
                My name is Christos, I am new to the forum here and i am posting from Greece.
                So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                So i tried asking for a schematic from the company and they would not give me one. Instead they...
                11-18-2024, 05:26 AM
              • Kemer
                Graphics Card mounting frame
                by Kemer
                Hello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
                As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
                I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
                What worries me right now is the possibility that...
                09-14-2024, 08:57 AM
                HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook Specification for Upgrade or Repair
                This specification for the HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) boardview and 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon...
                09-06-2024, 08:30 AM
