I have an Abit ST6E board aka "Casper", which is unfortunately not working. Because it's very rare board, I'd like to repair it, not matter the cost or how hard it will be. It's in 95% identical with ST6, only difference which I saw is that ST6E has different NB and SB (ST6E uses 815, while ST6 uses 815EP without IGP). I've already bought working ST6 for diagnostics, and maybe a part donor if needed.
Here is what I've found out already about this board:
- hangs on 00 code using PCI Diagnostic card, no matter what CPU
- reports the lack of CPU or RAM (by C1 code)
- came with Tualatin CPU which was dead I think, there was a two tone siren from beeper on this CPU
- I switched the bios chips between boards, bios chip from ST6E is working on ST6
- no physical damaged, no broken components or damaged traces, no badcaps
- voltages are present, there are also no shorts on main componenets (CPU, RAM, NB and SB).
Can anyone help me with diagnostics? I can handle all the replacements by myself, even the BGA.
Thanks,
Bartek
Thanks,
Bartek
