AsRock 775v88
  • aristos87
    desoldering
    • Mar 2009
    • DE
    AsRock 775v88
    Hello!
    I replace 21 bad caps (1000uF 6.3v) on AsRock 775v88.
    After testing the motherboard for several hours I mention that some caps gone bad again. So I replace them with bigger caps (1000uF but 10v) and it happen the same again.
    What is going wrong?
    Thanks.
  • Newbie2
    • Sep 2005
    • 885
    Re: AsRock 775v88
    Did you check that all of your new capacitors were installed with the right polarity?
    My gaming PC:
    AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
    ASUS M4A77TD AMD 770 AM3 Motherboard
    PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
    G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
    TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
    WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
    ASUS Xonar DG 5.1 Channel PCI sound card
    Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
    Antec Three Hundred Mid-Tower Case
    Microsoft Windows 10 Pro 64-bit
    Microsoft Windows 7 Ultimate SP1 64-bit
    • aristos87
      desoldering
      • Mar 2009
      • DE
      Re: AsRock 775v88
      Yes. The polarity was right. It's not the first time that i recap a baord. First time it happens.
      • Newbie2
        • Sep 2005
        • 885
        Re: AsRock 775v88
        ASUS and ASRock motherboards have the silkscreen for the capacitors different from what is commonly seen, on them the white shaded area on the circle is actually for positive.
        My gaming PC:
        • Toasty
          • Jul 2007
          • 4171
          Re: AsRock 775v88
          Yup. Somebody at Asus got their Ying mixed up with their Yang...
          veritas odium parit
          • aristos87
            desoldering
            • Mar 2009
            • DE
            Re: AsRock 775v88
            lol! Ok I reverse them all. Let's test now :p
            • 370forlife
              Large Marge
              • Aug 2008
              • 3112
              Re: AsRock 775v88
              Also, what brand/series are you using?
              • aristos87
                desoldering
                • Mar 2009
                • DE
                Re: AsRock 775v88
                On that motherboard I use those
                KZG
                https://www.badcaps.net/forum/attach...tid=1667&stc=1
                • stavi
                  Asrock 775V88+ mosfet identify
                  by stavi
                  I want to identify a mosfet. Unfortunately, I couldn't find the asrock 775v88+ schematic.
                  Does anyone know what this mosfet could be? It is between the agp port and the 1st pci slot. Q14 is his number.
                  Thanks for the help...
                  09-08-2022, 07:49 AM
                • gabrieljma1
                  Request: Full BIOS dump for ASRock Z790-CX (DDR5)
                  by gabrieljma1
                  I’m looking for a full raw 16 MB BIOS dump for an ASRock Z790-CX (DDR5) motherboard.
                  The board powers on (fans spin, RGB lights on, RAM LEDs active), but there is no display output and the VGA and BOOT LEDs stay lit.
                  I’m using an Intel i9-14900KF CPU (14th gen), and it seems the BIOS version on my board doesn’t support it yet. I tried to flash the official ASRock BIOS file (renamed .ROM → .BIN) directly using my RT809H programmer, but it didn’t work — monitor stays on but with black screen, so I believe the ASRock update file is not a complete...
                  10-08-2025, 03:32 PM
                • Exim
                  ASRock N100M, no picture no boot, but semi-alive
                  by Exim
                  Hi guys,
                  I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
                  ASRock N100M special features:
                  - CPU soldered to board, small Intel 12th gen
                  - iGPU
                  - four POST LEDs
                  Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
                  I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
                  Symptoms:
                  - no picture/signal on any of the display connectors,...
                  04-01-2025, 02:36 PM
                • MasterCap
                  What IC does AsRock usually use to make the PWM signals for GPU fans ?
                  by MasterCap
                  I have an AsRock Taichi 7900xtx, and the minimum fan speed is way too high at 1000rpm, and thats with it's Quiet BIOS switch on, and me setting the fan profile as low as it goes, while on.
                  Now 1 thing I could do is just make some circuit to put in between the fan the the GPU, and leave the fan on all the time, but anytime the GPU is sending the PWM for min speed, I'll just send something lower and quieter.
                  But does anyone know what how AsRock usually sends the PWM to the fans on GPUs and mobo's? Is it from the MCU that's often near the 12V inputs and fan jack ? Or is...
                  12-28-2024, 08:42 AM
                • Dev Goose
                  Help Needed: Reverse Polarity Issue on HP EliteBook 840 G4 – Where Do I Begin?
                  by Dev Goose
                  Hi everyone, I recently acquired an HP EliteBook 840 G4 (6050A2854301-MB-A01) that I'm hoping to bring back to life. I'm fairly new to laptop repairs but eager to learn and willing to put in the effort to understand and fix this. Any advice or guidance would mean a lot!
                  What Happened
                  The issue started when the laptop was accidentally plugged in with reverse polarity. Before this incident, the laptop would show a power/charging light whenever it was plugged in. However, now it's completely unresponsive—no lights, no power, nothing. I've been doing some research and understand
                  12-13-2024, 03:13 AM
