Hi guys
I have this H57H-AM2 V2.0 motherboard here, I'm trying to fix it to improve my own knowledge.
It has an i5-650 CPU. The board is basically dead - the fan spins but it doesn't beep or POST (00 on post diagnostic card), testing just with a bare board+CPU
What I have found is that the CPU voltage seems unusually low (unless I just need more experience to determine that is true) Also the CPU does not get warm with the heatsink fitted and without the heatsink it just heats up very slowly
The attached image shows what voltages I am getting. The first figure is with no CPU fitted and the second is with the i5 CPU
I don't have another LGA1156 CPU or motherboard here at the moment to prove if the CPU is any good
I did wonder if this is a BIOS problem as I have seen boards powering up but acting 'dead' with a corrupted BIOS, but I don't know how to program the BIOS as it appears to be embedded in the Super IO chip IT8721F.
I assume I can use an exterrnal SPI programmer but how do I connect that? I found some tutorials for that on youtube but from what that taught me i need to know where to connect CS, MOSI, MISO and SCLK.
There are 4 header pins right near the IT8721F but two of those pins connect to ground so that can't be what I need, and I couldn't find a datasheet nor any info in the motherboard manual.
