ASRock P4i65GV killed by PSU Fuhjyyu's
  • LesCoke
    • Aug 2009
    • 6
    I have an ASRock P4i65GV Prescott 800 Dual Channel DDR400 motherboard that became unstable after a few months being powered by a recycled Antec True550 PSU.
    I just joined yesterday, and this is my first post to this forum. I'm an experienced computer software developer, with a background / hobby in electronics design and servicing. So this post is more to document my recap for others who may have the same PSU and motherboard.
    I acquired the Antec True550 after upgrading a dual Xeon system for a client; they needed a proper EPS12V PSU for dual CPU upgrade. Thinking it was still in decent shape, It found it's way into an in-house ASRock / 3.2GHz Celeron-D system upgrade.
    After a few months the system became unstable, and seemed to be running warmer than usual. Upon opening the case, I saw the blown caps around the CPU. They are the 10x25mm 3300uf 6.3V Nippon Chemi-Con KZG series. As stated in other threads, except for a bad batch a few years back, these should be decent caps. But then again that is about the same time the 800 Mhz FSB Socket 478 Prescott was popular.
    I was familiar with this forum from prior referencing, and after reading a few threads I confirmed my suspicions of the suspect PSU. Upon PSU inspection I found it was one of the units built by CWT using the failure prone Fuhjyyu's.
    I shopped Mouser and Digikey for suitable replacements. I was leaning towards the panny's but could only find them in the larger 12.5mm diameter. I narrowed my search parameters to 10mm and found comparable replacements at Mouser. A mixture of Nichicon HM, HN, and HZ series. I would have preferred to use HZ series for the main 3300uf 6.3v, but only the HM was in-stock. The HM ESR and ripple current specs are identical to the KZG specs, so they should work until the HZ are restocked.
    I should have my caps today or Monday. I will take before and after pictures and post them here with more details on the specific caps values used and where. Feel free to chime in with any thoughts.
    Les
  • c_hegge
    • Sep 2009
    • 5219
    Re: ASRock P4i65GV killed by PSU Fuhjyyu's
    I've experienced similar problems. Antec PSUs made by Channel Well often had bad caps. It was a shame as they were good in every other way. When re-capping them, I've also had problems finding caps in 10mm size. I just use the 12.5mm (Nichicon HE and Panasonic FC/FM) and mount them a slightly above the PCB.
    The chemi-con KZG caps on your are ok as long as they don't get hot. They are often fine in cooler areas, such as between PCI slots, but if they are near the CPU or northbridge, they almost always fail.
    Also, if you're going to use nichicon HM or HN, make sure the date code is 2005 (05xx) or later as they were defective B4 that.
    Anyway, let us know how the re-cap goes.
    • gabrieljma1
      Request: Full BIOS dump for ASRock Z790-CX (DDR5)
      by gabrieljma1
      I’m looking for a full raw 16 MB BIOS dump for an ASRock Z790-CX (DDR5) motherboard.
      The board powers on (fans spin, RGB lights on, RAM LEDs active), but there is no display output and the VGA and BOOT LEDs stay lit.
      I’m using an Intel i9-14900KF CPU (14th gen), and it seems the BIOS version on my board doesn’t support it yet. I tried to flash the official ASRock BIOS file (renamed .ROM → .BIN) directly using my RT809H programmer, but it didn’t work — monitor stays on but with black screen, so I believe the ASRock update file is not a complete...
      10-08-2025, 03:32 PM
    • Exim
      ASRock N100M, no picture no boot, but semi-alive
      by Exim
      Hi guys,
      I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
      ASRock N100M special features:
      - CPU soldered to board, small Intel 12th gen
      - iGPU
      - four POST LEDs
      Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
      I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
      Symptoms:
      - no picture/signal on any of the display connectors,...
      04-01-2025, 02:36 PM
    • MasterCap
      What IC does AsRock usually use to make the PWM signals for GPU fans ?
      by MasterCap
      I have an AsRock Taichi 7900xtx, and the minimum fan speed is way too high at 1000rpm, and thats with it's Quiet BIOS switch on, and me setting the fan profile as low as it goes, while on.
      Now 1 thing I could do is just make some circuit to put in between the fan the the GPU, and leave the fan on all the time, but anytime the GPU is sending the PWM for min speed, I'll just send something lower and quieter.
      But does anyone know what how AsRock usually sends the PWM to the fans on GPUs and mobo's? Is it from the MCU that's often near the 12V inputs and fan jack ? Or is...
      12-28-2024, 08:42 AM
    • nolaryie
      BIOS .bin file for ASRock B450M Steel Legend
      by nolaryie
      Hi, I’m looking for a clean, working BIOS .bin dump (16MB) for the ASRock B450M Steel Legend motherboard.
      I’ve already tried flashing the official ASRock ROM file via CH341A, but it won’t post — I believe the capsule format is incompatible.
      Any BIOS version that supports Ryzen 5 2600 is fine (e.g., P2.30–P3.60).
      If anyone has a working board and can dump the BIOS using CH341A or flashrom, I would really appreciate your help.
      Thank you!
      08-06-2025, 12:01 PM
    • khanhtq0
      Full BIOS Dump for ASRock H310M-HDV Rev 1.02 (MX25L12873F)
      by khanhtq0
      I'm looking for a full BIOS dump (.bin) for the ASRock H310M-HDV Rev 1.02 motherboard. The BIOS chip is a MX25L12873F (128Mb / 16MB).
      I’ve already tried flashing the official BIOS from ASRock (version 1.40 and 3.30), but those are Instant Flash versions and don’t include the full SPI image (e.g. Intel ME Region, Descriptor, etc.). After flashing, the board powers on only when I short PS-ON to ground, and it fails to generate Vcore and 2.5V. Other rails like 1.05V and RAM voltage are present.
      I suspect the original Intel ME and descriptor...
      08-06-2025, 02:14 AM
