ECS K7S5A Rev. 3.1 but different caps
  • lucky13
    • Aug 2007
    • 412
    I am recapping this board for a friend.
    When I searched old posts, I found this one by Rainbow
    Rainbow's board
    His board is Rev 3.1 and so is the one I am working on now.
    However, his caps are 3300uF and mine are 6x 2200uF near the CPU and 3x 1800uF/6.3V at the input VRMs!
    So, what is going on?
    Should I redo all mine as 3300uF?
    Or, I can do 3300+1000 for each of the 3 phase VRM?
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: ECS K7S5A Rev. 3.1 but different caps
    https://www.badcaps.net/forum/showpo...5&postcount=23
    • lucky13
      • Aug 2007
      • 412
      Wow, polys on ECS...8x820uF but then yours have 4 phase VRMs
      OTOH, if I want to go "budget", should I do 2x3300, 2x2200 (original) or 3300+1000 (ultra cheap)?
      • Newbie2
        • Sep 2005
        • 885
        It's recommended to use the same values of caps as the ones on your motherboard when you replace them.
        Aluminum electrolytic capacitors are usually very low-cost components.
        My gaming PC:
        AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
        ASUS M4A77TD AMD 770 AM3 Motherboard
        PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
        G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
        TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
        WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
        ASUS Xonar DG 5.1 Channel PCI sound card
        Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
        Antec Three Hundred Mid-Tower Case
        Microsoft Windows 10 Pro 64-bit
        Microsoft Windows 7 Ultimate SP1 64-bit
        • lucky13
          • Aug 2007
          • 412
          Recapped with 2200uF/6.3V and all is well.
            by momaka
            03-12-2025, 03:42 PM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
          • Foetuss
            Gigabyte GA-6OXT :: caps question
            by Foetuss
            Good evening
            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
            But I was also suprised about the bigger boys, which are 330µF 25V.
            Could it be they used 25V caps because they were cheaper / available at that time?...
            02-11-2025, 12:22 PM
