PSU requirements for FIC AU31 or K7MNF-64?
  • gdement
    • Jan 2007
    • 690
    Short version:
    I'm looking for the original PSU ratings for each voltage rail, cross load limitations etc for the power supplies that were originally used with the FIC AU31. I know that board was killed by lots of infamous Bestec eMachines computers, so I bet there's lots of people here who might have those PSUs around.
    I need a power supply for a very similar board (FIC K7MNF-64) so knowing those amperage values would help identify a good replacement.
    Long version:
    I recently bought an FIC K7MNF-64 motherboard. This board is very similar to the AU31, in fact the person selling it was advertising it as a replacement for Gateway/HP/etc machines that originally had the AU31 in them.
    In my case, I'm using it for a low-budget fix/hotrod of an old MicroATX P3 Dell, and obviously have to replace that power supply (proprietary pinout).
    I intended to use an FSP 300W power supply, same as one I use on a full size nForce2 ABit AN7 board. It powers a fully loaded AN7 perfectly, but to my surprise it's slipping against the K7MNF-64.
    With just a single 512MB module installed, at 166FSB, and a mobile Thoroughbred that's probably running underclocked, I'm getting these voltages in the bios:
    Vcore 1.58
    3.3 3.32
    5 5.02
    12 11.58
    Everything's fine except the 12v rail. Technically 11.4v is legal but I don't want it this low. It's only going to get worse when I add load to it.
    I do have some AcBel 550W psus that have been discussed in this forum before. They're great for newer boards but last time I tried to use one on my AN7 I ruined the 3.3v supply in about 1 week. The 3.3+5v rating on those AcBels is pretty modest. Maybe it's fine though - I don't know what this board needs. I'd feel better about using the AcBel if I could compare values from the OEM psu for an AU31 (which I don't have).
    I looked up the psu from a representative AU31-based emachine, and came up with these part numbers:
    eMachines p/n: 100929 (300W psu)
    SKU: PWEM100929A3
    Can't find anything online that tells the amperage ratings for each rail, or the combined 3.3+5v wattage limit.
    I may just throw an AcBel at it and hope for the best, but if somebody has the ratings from an AU31 psu it would be much appreciated.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: PSU requirements for FIC AU31 or K7MNF-64?
    Add a hard drive or two and see what +12v does.
    It may not be loaded ENOUGH to regulate properly.
    Mann-Made Global Warming.
    - Dr Seuss
    • gdement
      • Jan 2007
      • 690
      Turns out I was mistaken, it actually had power connected on a hard disk and cdrom. They just weren't hooked up to the board.
      The previous processor was running at 1000/166. Swapped it to a palomino 1400/133, supply voltages are still exactly the same.
      It seems to work fine in memtest86 and booted knoppix okay. The 12v reading is consistent but I don't like it.
      • gdement
        • Jan 2007
        • 690
        Testing with 1gb ram and a ti4200 video card still gets the same 11.58v reading. It's like the board just wants it there.
        5v dropped a negligible amount, that's all.
        I think I'll try the AcBel though. When I burned out the other one it was with a ti4200 that I think guzzles 3.3v. Just using onboard video with this machine.
        • gdement
          • Jan 2007
          • 690
          Hooked up an AcBel, now everything is slightly low but well within spec.
          3.3 3.26
          5v 4.91-4.94
          12v 11.84-11.90
          I'll check it again after it logs some miles and see if anything is slipping.
          Conveniently, the 20 and 4pin connectors on this board are properly positioned to fit a 24/8pin PSU. I really like the connectors on this board, everything fits without modification, even the Dell front panel connector (actually an Intel spec pinout).
          If anybody knows the amperage values from an AU31 eMachine that would still be great to know for comparison purposes. Thanks.
          • 370forlife
            Large Marge
            • Aug 2008
            • 3112
            Wait, you are looking at these in the bios...
            (Bonez...pay attention!!)
            Use a Digital Multimeter, the bios (and any software...) is almost always inaccurate.
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Pay attention to what?
              As I recall gdement uses [or knows how to] a scope.
              Pretty sure he knows when to confirm with a DMM.
              - Dr Seuss
              • 370forlife
                Large Marge
                • Aug 2008
                • 3112
                Vcore 1.58
                3.3 3.32
                5 5.02
                12 11.58
                Didn't say anything about using a DMM.
                • gdement
                  • Jan 2007
                  • 690
                  I don't think the low 12V reading was false since it went up when I swapped PSUs. I've never seen BIOS readings disagree with multimeter, but it won't hurt to check that anyway.
                  If the readings hold as they are with the AcBel then it's no problem. My only worry is whether the AcBel's 3.3 or 5v rails are underrated for this board, because I had the 3.3v die on another board once. But no slipping so far after memtesting overnight.
                  No scope here.
                  • eagle3
                    • Sep 2009
                    It's an nForce2 board and uses principally the +12v rail,
                    Amperage requirements will depend on hardware installed, particularly graphics card.
                    Something like
                    +12V - 20A
                    +5V - 30A
                    +3.3V - 30A
                    should suffice in most cases.
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      iirc the fic au31 emachines board runs the vcore vrm from +5
                      • gdement
                        • Jan 2007
                        • 690
                        I gave it back to the owner, seems to be running fine so far.
                        • Byte_76
                          Understanding capacitor ratings
                          by Byte_76
                          Hi, I have some capacitors that I need to replace on a graphics card.
                          I've attached pictures for reference.
                          Please help me to understand the ratings so that I can order the correct replacements:
                          1. G7 560 2.5E - I believe these are for vcore
                          • Is this 560uF and 2.5V?
                          • What does the "E" mean?
                          • Is there any relevance to the "G7"
                          2. ECX 17 560 2.5V - I believe these are on the memory phase
                          • Another 560uF at 2.5V?
                          • This is on the same graphics card. If the caps are rated the same as those above, why are they a different type?
                          05-10-2024, 07:56 AM
                        • Arkadiy84
                          Dell Latitude 5430 LA-L591P Ratings of resistors
                          by Arkadiy84
                          Hello. Tell me the ratings of resistors 1 and 2
                          03-16-2024, 03:22 PM
                        • lpzrules
                          Help with acbel pch018
                          by lpzrules
                          hello
                          I have both the psu one is for lenovo other for hp
                          my pch018 is blown but pch019 is functional and of no use to me
                          actually on the psu board of both models the ps_on wire which has green black and yellow which goes into motherboard for supply is 4 pin soldered on it has 4 squares and wires soldered together
                          the pch018 uses 3 slots one is empty all blacks and yellows are separate and one gree separate pch019 uses all 4 slots with mix of yello black and green
                          there are 9 wires inpch018 and 10 in pch019
                          the pch018 has output from...
                          06-20-2025, 04:21 AM
                        • ProdigyS10
                          FIC AU31 No longer posting
                          by ProdigyS10
                          I have an FIC AU31 i'm hoping to resurect to be a win98SE retro pc. has a athlon xp 3200+ cpu.
                          it had bad capacitors on it causing reboots (or so i thought), replaced the capacitors 4 of them had opened up. we didn't do a very clean job. but it worked and the system seemed stable. during this testing though i had a pci card that was up slightly and without thinking i pushed it down and
                          the system hung. i tried rebooting and wouldn't get any post beeps after that. ive since upgraded my solidering/desolidering station and cleanly mounted the capacitors nicely hoping that it was just...
                          01-18-2023, 03:48 PM
                          Surface Mount Fuses Fundamentals Datasheet
                          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                          10-07-2024, 06:07 AM
