Hello all I was planning on recapping my N7NCG 400, the VRM section is what has me concerned. It has 4 3300UF 6.3 OST RLX capacitors and 3 2200UF 16V caps also RLX. I was wondering if I can go 10V caps for the 2200UF I wanted to do some older nichicon HM for this VRM. The last thing I want to mention is the 2200UF 16V caps look to be OST black RLS on other boards and I thought the RLS wasn't a ultra low ESR cap so I thought maybe I could get away with regular low ESR for the 2200 caps like a panasonic FM or something.
Biostar N7NCG 400 v7.2
My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 ProTags: None -
Re: Biostar N7NCG 400 v7.2
After doing research I decided to try the new Panasonic FS 2200uf 16v in place of the OST RLX. Will update when they get here and have pics of the before and after recaps. otherwise I got NOS Nichicon HM for the rest of the board.My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro -
May we see some pictures of the board? The images I'm getting through searches on the internet are being inconsistent. If that board has a 4-pin 12V CPU connector, then NO, you cannot use 10V caps to replace 16V caps, because it means those 16V caps are likely connected on the 12V rail.
And yes, Panasonic FS should work fine for the recap - both for the OST RLX and RLS. RLX is supposedly motherboard-grade ultra-low ESR, but their specs trail those of Nichicon HM and Rubycon MBZ by a fair bit. Meanwhile, series like Panasonic FM and FR are not that far behind the RLX specs. So in a pinch (especially now that mobo-grade ultra-low ESR caps like HM/HN/HZ and equivalent are no longer made), Panasonic FM, FR, and FS should work alright. I think the Rubycon-equivalent of those are the ZLS. For Nichicon, it should be HW. All are still active parts, as far as I know.Last edited by momaka; 01-23-2019, 10:35 PM.Comment
I googled it and it doesn't have a 12v 4 pin CPU connector.May we see some pictures of the board? The images I'm getting through searches on the internet are being inconsistent. If that board has a 4-pin 12V CPU connector, then NO, you cannot use 10V caps to replace 16V caps, because it means those 16V caps are likely connected on the 12V rail.
BigTroll: You can measure the voltage on the places where 16v OST caps were and check the voltage going through. Most likely it's an design similar to ASUS' A7N8X-E Deluxe where they got away with an boatload of 3300uF 6.3v caps and no 4pin 12v connector.Main rig:
Gigabyte B75M-D3H
Core i5-3470 3.60GHz
16GB DDR3-1600
Samsung SH-224AB DVD-RW
Delux MG760 case
Hi guys so I did order the 2200uf 16v pannasonic caps that are 10mm. I finished recapping the board but have to wait on mouser to ship the panny caps and they are taking forever.My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 ProComment
The recap seems like a success so far 2 passes in memtest where it kept erroring out before, will let it run all night and see how she does. Its a athlon XP-M overclocked to 2.4ghz with 2gb ram, 200gb WD IDE, DVD-RW, ATI X800 PRO.
One More thing I want to mention using a temperature gun, the OST caps were running 100-110F when taking the temps, the new nichicons are only 89-95F or so. I took the temps while the system was running memtest for 30 mins both times.Last edited by BigTroll; 01-26-2019, 07:18 PM.My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 ProComment
the jap caps can hold and store energy significantly better than the osts so the regulators and mosfets need to work less harder to keep up with the demands of the switching circuit, hence the cooler temperatures.Comment
Or maybe the OST's parameters (ESR, capacitance, leakage current, etc...) just degraded over time (which is quite possible given the previous memtest errors), if the specs of that batch weren't exaggerated to begin with. I take it those older Nichicon HMs were made after 2004 or 2005. I think the low temperatures are probably because of the low TDP (albeit overclocked) Athlon XP-M.Comment
Nice recap job and awesome classic rig!
I like how you have a red AMD motherboard, red ATI video card, and... red LED fan. Go Team Red!
BTW, that ATI X800 Pro looks like the old gen, before ATI started using a separate AGP bridge chip. Make sure to keep it cooled well (might want to invest into a bigger heatsink). Otherwise, it'll probably fail over time.
Not to say your measurements are not true... but all I will say is that I don't usually trust those laser temperature "guns". Depending on the color and surface texture of the material (i.e. dark vs. light and smooth/reflective vs. rough), the temperature can vary quite a bit. Granted cap sleeves are typically pretty smooth, so there likely won't be much error in those readings (at least in the temperature differences). Still, I rather use my type-K thermometer.Comment
So ive had some issues, My computer would not get through 3d mark 03 it would lock up with the ATI card, it would make a few passes through 3d mark 01 but would eventually lock up after that. I figuered part of the problem could be the nforce2 AGP Gart driver not playing nice with ATI, so I put in my best nvidia card I had left a QUADRO FX 1000, it made it through 3D mark 03 no problem and looping 3D MARK 01 it would last about 2 hrs then crash with a message about not having enough vram but the computer was not hard locked.
Was hoping someone had some suggestions.My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 ProComment
Benching on a fresh install of XP Service Pack 3 with no updates done to it. and using 3DMark 2001SE. I will try and let it run again so I can get a picture of the error message.My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 ProComment
Is AGP fast-write enabled in BIOS on your motherboard? Sometimes, I've had that cause issues with AGP video cards. I haven't noticed any loss of performance with it turned off for high-end cards either, so I usually keep it off now.
Also, what about "Cache Video Memory" (or similar option) in BIOS? Try disabling that too, if you have it.
If bad comes to worse... why not play some oldschool games on it for a few hours to see if it would crash?
If it doesn't crash then, then I'd say the system is "stable enough".
Another idea: maybe try OCCT or some other similar CPU-only (or CPU + memory) stress test. If the system crashes with that, then most likely your GPUs weren't the issue.Comment
when jumping ship with video cards, its also important to use a third party driver uninstaller like driver cleaner or DDU (display driver uninstaller. requires .net lamework 2.0) to wipe all traces of the previous video driver in the registry and filesystem. otherwise the drivers from the opposing video card maker wont work properly due to conflicts with each other. i think nvidia and ati/amd do this deliberately to stop people from jumping ship. sooner or later, someone is going to catch on to this shit that they are doing and file a class action lawsuit for anti-competitive behaviour/practices...
Nah, I'm pretty sure there is no such a thing.when jumping ship with video cards, its also important to use a third party driver uninstaller like driver cleaner or DDU (display driver uninstaller. requires .net lamework 2.0) to wipe all traces of the previous video driver in the registry and filesystem. otherwise the drivers from the opposing video card maker wont work properly due to conflicts with each other. i think nvidia and ati/amd do this deliberately to stop people from jumping ship.
On my video card test PC (yes, I have a PC dedicated for testing video cards
), I keep both nVidia and ATI drivers running simultaneously. The nVidia drivers are actually pretty smart and don't start up if there is no nVidia video card. Meanwhile, the ATI ones are always running and often bitching if they encounter a non-ATI card (or one they don't recognize, because it's too old or too new)... but nevertheless, they don't stop the nVidia drivers from running if there is an nVidia card in the system. Likewise with nVidia drivers.
Thus, I rarely have to do any driver installations when testing various video cards. Most of the time, the already-running ATI and nVidia drivers pickup the video card after first boot, then install the drivers (after some 5 minutes of waiting due to slow HDD in that PC), after which I reboot the PC and everything is running properly with the right driver. What's more interesting is that neither the nVidia nor ATI drivers care if I am testing AGP or PCI-E 16x or PCI video card (and the motherboard in that test PC has all three.)Comment
I have had to use driver cleaner pro or something to remove some bad nvidia drivers version 81.98 or something, they would crash screen savers in windows 98 and nvidia's installer would not removed them.I think it might be a good idea to try that since I used about 5 different versions of catalyst on the system.
So update, I got some used ram off ebay, nicer Kingston with heatspreaders. running 2GB with 2.5-3-3-6 timings and running memtest but they seem to be doing okay. I also bought a cheap FX5700 off ebay. I really would like a 6600GT or 6800 but anything high end AGP is outragous in price. So i'll try running 3d mark looping on it after i get it in.
I did play colin mcrae 2005 on it with the original ATI card for 30 mins or so with no problems, heck that X800PRO even pushed it at 1920x1080 on a newer monitor I was very impressed. no way a Geforce FX could do that...
Also wanted to mention I did turn off AGP fastwrite in bios and I don't think I am caching the video bios or anything, I set AGP aperture to 256 if the card was 256 or 128 if I was running the 128mb nvidia card however I could change it to 512. I am honestly not sure what would be the best aperture setting.Last edited by BigTroll; 02-06-2019, 10:56 PM.My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 ProComment
Oh, man, I hope it's not one of those Chinese variants. Not that there is anything wrong with them in terms of performance. But they always seem to come with Sacon FZ capacitors - some of them even ventless Sacon FZ!
6600 GT you can still find for around $15 shipped (in the USA) occasionally. Just have to be patient and spot an auction that no one else bids on. 6800 GT is a mixed bag - sometimes they go for a more "reasonable" price (under $30), and often times not (typically twice that).
Meanwhile, ATI seem to be cheaper. In fact, for the price of a "cheap" 6800 XT or GT, you can typically get a new HD2600 or HD3650 from China. Both the HD2600 and HD3650 will come close or even beat the 6800 in many games. Only problem with these new Chinese ATI cards... they too will come with Sacon FZ most likely.
Otherwise... yeah, prices on high-end AGP cards - especially nVidia - regularly go through the roof. Funny, though, nowadays the old stuff like GeForce 3 and 4 TI series sell for even higher prices than some other high-end AGP video cards (I've seen a few go for even more than the GeForce 6800 cards.
And considering those old CMR series are better optimized for nVidia... that is indeed pretty impressive from the X800 card.Comment
What PSU are you using for graphics card benching? Check the caps.So ive had some issues, My computer would not get through 3d mark 03 it would lock up with the ATI card, it would make a few passes through 3d mark 01 but would eventually lock up after that. I figuered part of the problem could be the nforce2 AGP Gart driver not playing nice with ATI, so I put in my best nvidia card I had left a QUADRO FX 1000, it made it through 3D mark 03 no problem and looping 3D MARK 01 it would last about 2 hrs then crash with a message about not having enough vram but the computer was not hard locked.
Was hoping someone had some suggestions.Comment
I got a Enhance ATX-1136F its a 360 watt it was new old stock, I did open it and found jamicom and teapo it looked to be a 2006 build, I ran it on a PSU tester before i put it in the system. it seems to be doing fine but I will check the caps soon.
I also got the FX5700 its a ASUS V9570, lubed the fan it had small rust spots on the dvi connector and looked like it was in a bit of water at one point but It ran 3dmark01se 700 plus tests before it locked up but that pretty good, it lasted at least 6 hours in 3dmark before crashing. I will continue to work on this system. and I appreciate your feedback everyone.My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 ProComment
by nick3092I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
Channel: General Capacitor Questions & Issues
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by cloppy007I've found out that the all the Nichicon HM(M) caps on this board are faulty and need replacement. However, I didn't plan in advance and I don't have good replacement caps.
The original values are 2200uF, 6.3V, 5mm pitch. According to the datasheet, the rated impedance should be around 13-18 uOhms.
There are 8 of them, 3 to the left of the CPU socket and 5 on the bottom, very close to the northbridge. They are all connected, according to my multimeter.
I think I recall hearing that I don't have to use the same capacitance for in series...08-21-2023, 03:18 PM -
by eryjusHello,
Howdy folks,
I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...-
- Loading...
