Dell Dimension 8300 VRM
  • bgavin
    • Jan 2007
    • 1355
    Please see the attached photo.
    My daughter's machine has mixed poly and electrolytic caps in the VRM.
    All the VRM caps are bulged and/or leaking. 820uF/6.3v.
    There are two polymers at each end of the VRM cap string.
    Q: should I recap with MCZ or see if I can find more 560uF/4v polys?
  • lucky13
    • Aug 2007
    • 412
    Re: Dell Dimension 8300 VRM
    I hear everyone is recommending polys.
    Which type you have on hand?
    Personally, I am waiting for some polys I had ordered to play with....
    • bgavin
      • Jan 2007
      • 1355
      KC8 responded in another thread...
      I guess the plan is to pull all ten pieces... four good OSCON 560 and six bad 820 lytics, replace all ten with 820 OSCON.
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        Are these Nichicon HM/HN? If so, maybe you should pull all of them off the board if they are the ones with the bad date codes. MCZ should probably work fine as a replacement. Polys will be nicer, of course .
        • bgavin
          • Jan 2007
          • 1355
          The defective caps are all MCZ.
          Obviously went over temp and burned up.
          This is a shitty design case and prone to over heating.
          I told the client to throw it out and buy a new machine.
          • bgavin
            • Jan 2007
            • 1355
            I am amazed at how trashed this GX270 is. Nearly all the caps are leaking or bulged, yet it still works.
            The southbridge is VERY hot, as is the crappy little power supply unit.
            The PSU fan is working.
            Hot, hot, hot.
            No wonder all these caps popped.
            This design is a complete piece of shit.
            The only thing of value on this machine is the 3.0 P4 Northwood.
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              Haha, I hope you where kidding right?
              You know those Core 2 Duo CPU's are basically free with the CPU fan nowdays
              • Wizard
                • Mar 2008
                • 2296
                In that case may I have the 3.0GHz P4? Would be nice for my work at our shop (currently 2.8C).
                Cheers, Wizard
                • bgavin
                  • Jan 2007
                  • 1355
                  Thanks for the chuckle.
                  Tell that one to a client with a critical socket-478 machine that cannot be replaced with a 775 board.
                  • bgavin
                    • Jan 2007
                    • 1355
                    Damn. After all that farting around with my Wai Fong order, I find out I brain-farted and order 10mm polys. I hope I can find a use for 50 of the 820/4/10mm caps.
                    So... I did another 820/2.5/8mm bulk order from a different source.
                    Stupid. Dump.
                    Disassembling this board from the Dell case tray is quite annoying.
                    The processor HSF bracket ties the board to the tray.
                    Those old Intel 478 brackets and push-pins really suck.
                    • bgavin
                      • Jan 2007
                      • 1355
                      The recap was a success using 820/2.5v polymers.
                      The leads are indeed a bit thicker, and required more cleaning with the needle.
                      This machine also had bad caps on the video card.
                      This was a first for me, and I replaced four popped 1000uF/6.3 with 10v MCZ.
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        bgavin; haha, I was just kidding, take it lightly man
                        http://cgi.ebay.com/Intel-Pentium-4-...mZ400055076201
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          i got a p4 presscott-a (no ht, 533fsb) emachine for almost free in a trade
                          all i put in was my old compaq presario 5000 with amd atlon 1.2 ghz
                          what i got was missing cd drives/hd, pci express 16x port and had charred bestec pos ps
                          but it had 1.5 gb of ram with it
                          dang it runs fast with ubuntu
                          sigpic
                          (Insert witty quote here)
                          • bgavin
                            • Jan 2007
                            • 1355
                            No worries.
                            Ick. A Prescott. Not worth shit, let alone $19.95.
