recapped AOpen AK77-600 Max
  • Achelon
    • Apr 2009
    Just gonna say a big thanks to you guys. From the info on this site I was able to repair my AOpen AK77-600 Max board. It worked for 4 years then developed random crashes.
    I checked the board and all the 2200uf KZG caps in the CPU VRM had failed. I replaced them with Panasonic FC's and prime95 has been running for 12 hours now with no problem and vcore is rock stable.
    As an interesting aside, the mobo manual devotes 2 pages to these caps, describing them as:
    "The quality of low ESR capacitor (Low Equivalent Series Resistance) during high frequency operation is very important for the stability of CPU power. The idea of where to put these capacitors is another know-how that requires experience and detail calculation."
    Regards,
    Achelon
  • Gianni
    • Jul 2008
    • 681
    • Italy
    Re: recapped AOpen AK77-600 Max
    Congratulations and welcome on Badcaps
    Gianni
    "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
    H. J. Brown
    • 370forlife
      Large Marge
      • Aug 2008
      • 3113
      In their defense, UCC KZG's should have been good, but UCC made a few mistakes on them.
      • c_hegge
        • Sep 2009
        • 5219
        The problem with KZG is just that they don't like getting hot, so if they're located near the CPU they often fail. Also, Panny FC aren't a recommended replacement for KZG. If you're going to use Panasonic, use FJ series, although I suppose if it works, it works.
        • Toasty
          • Jul 2007
          • 4171
          The FJ's (and FL's) sound great, so do Sanyo's, but sourcing them is a problem. Most appear to be old stock/overstock buyouts from manufacturers. Ebay is a resource, but they're all coming from China suppliers.
          Ruby's & Samxon are available right from Badcaps.net. Nichicon HZ's from Mouser. Panny FM's (not a first choice in VRM's, but certainly better than FC) from Digikey.
          Toast
          veritas odium parit
          • kahlil88
            AOpen MX36LE-UN which replacement caps?
            by kahlil88
            Just got a computer with this board and ALL of the Lelon RXA caps have failed. Having trouble finding datasheets to match against potential replacements. The caps in question are 7x 1500uf 6.3V 10x20 and 11x 1000uf 6.3V 8x12. Open to replacing with polymers as long as it works.
            10-23-2025, 03:14 PM
          • mnciks11
            3.3v/5v - VFB (Feedback) should be 2V proven by calculation
            by mnciks11
            Hello guys
            The 3.3v and 5v always
            Hope you are all okay brothers, i went through voltage dividers,Calculations, for those who are new a specially, it's so true that when check the Feedback pins for 3.3v always and 5v always you should get 2V on those pins...
            Below is the link to my calculation calculating the Feedback volts
            https://youtu.be/Ufks5ucea5w...
            11-27-2021, 12:27 AM
          • browny1978
            Recapped BP6 and HPT366 issue
            by browny1978
            So I'm an owner of a BP6 and it was in fantastic condition, with none of the original capacitors showing any signs of failure. But one day a year or so back, it failed to Post, after working fine just a few hours earlier.
            So I did the usual, swapped all the components etc. etc. to no avail. So I boxed it up and thought I'd deal with it another day.
            About a month back i recapped the board with Rubycon caps all of the ratings as per this site, but still to no avail. No post.
            So I bought some SST BIOS chips that were of similar spec to the winbond one...
            08-25-2021, 01:07 PM
          • MAJACAEM
            AOPEN WT10–FRG chromebook locked
            by MAJACAEM
            Hello fiends
            This chromebook arrive locked with mdm, I try to start SO in devmode but still locked , system message said “Developer mode disabled by owner” system return to normal mode.
            I try steps such as ctrl v …
            04-23-2022, 08:09 AM
            Wise Wing F199 19'' LCD monitor - recapped
            by momaka
            Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
            I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
            When I saw the Craigslist post, I wasn't...
            08-24-2020, 10:58 AM
