Two motherboards, need help to fix them.
  • Dan81
    SNES-powered
    • Oct 2013
    • 1865
    • Romania
    As the title says, I have two motherboards with two problems:
    MB 1 - MSI P35 Neo2 - accidentally shorted it and now it won't turn off. It DOES POST though, tested with known good RAM and GPU and got POST. Just the power button does not respond at all. (reset does)
    MB 2 - ASUS A7N8X-E Deluxe - southbridge gets hot to the touch (suspecting it dead but not sure yet) but this one DOES respond to the power button and WILL turn off. It does also spin the fans but no beeps, nothing. Just the SB getting hot. (nVidia MCP-T)
    Any ideas what to do?
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
  • Dan81
    SNES-powered
    • Oct 2013
    • 1865
    • Romania
    Re: Two motherboards, need help to fix them.
    Answered half of my problem with the A7N8X-E.
    ASUS was cheap enough to use LTEC LZP caps on this variant although the VRM section is the same I remembered back on the older one I had - KZGs that ironically haven't died yet.
    Now it's ready for a recap. I'm pretty sure the SB gets hot cause of dead LTEC caps. Otherwise it would either not turn on AT ALL (had that happen with a ECS 945PL-A) or would power on as soon as AC is applied.
    Main rig:
    Gigabyte B75M-D3H
    16GB DDR3-1600
    Delux MG760 case
      • 30934
      1st one,
      check if there is a diode across the switch line that's shorted.
      • Dan81
        SNES-powered
        • Oct 2013
        • 1865
        • Romania
        Originally posted by stj
        1st one,
        I'll check although most of that zone is filled with SOT-89 package transistors and a NIKO-SEM driver chip (most likely)
        Main rig:
        Gigabyte B75M-D3H
        16GB DDR3-1600
        Delux MG760 case
        • Dan81
          SNES-powered
          • Oct 2013
          • 1865
          • Romania
          Replaced the only diode across the switch pins. No dice, same behaviour.
          Main rig:
          Gigabyte B75M-D3H
          16GB DDR3-1600
          Delux MG760 case
            • 30934
            diodes would be in 3pin smd packages, you usually find a protection diode between each input and ground.
            • Dan81
              SNES-powered
              • Oct 2013
              • 1865
              • Romania
              Yes. I replaced one of those near the PWR_SW pins. No change. The board does the same as before.
              There's nothing overheating or anything unusual. Just the board powers on as soon as plugged in. It will work as normal, functions and everything. Just the power button won't turn off the board, requiring to pull the plug.
              Main rig:
              Gigabyte B75M-D3H
              16GB DDR3-1600
              Delux MG760 case
                • 30934
                wont turn off at all, or turns off and reboots?
                btw, could also be a shorted ceramic cap - meter the resistance of the switch line to ground,5v and 3.3v
                • Dan81
                  SNES-powered
                  • Oct 2013
                  • 1865
                  • Romania
                  Simply won't turn off at all.
                  Amusingly, the power switch acts as a 2nd restart button instead of shutting down.
                  Main rig:
                  Gigabyte B75M-D3H
                  16GB DDR3-1600
                  Delux MG760 case
                  • peterflax
                    • May 2018
                    • usa
                    i have the problem ! havent been able to find the solution just posting this so i can follow this post "ignore me "
                      • 30934
                      maybe reseting the cmos settings would help.
                      • Dan81
                        SNES-powered
                        • Oct 2013
                        • 1865
                        • Romania
                        There's no battery in the CR2032 slot.
                        Main rig:
                        Gigabyte B75M-D3H
                        16GB DDR3-1600
                        Delux MG760 case
                        • Sparkey55
                          • Jan 2010
                          • 1523
                          Put a fresh new battery in it.
                            • 30934
                            that would help!
                            • Dan81
                              SNES-powered
                              • Oct 2013
                              • 1865
                              • Romania
                              I know what you're both thinking about (Power on AC loss) but that's not the case here, since even then the board should power cycle. Instead, on this one it will not turn off even if I would disable that.
                              Main rig:
                              Gigabyte B75M-D3H
                              16GB DDR3-1600
                              Delux MG760 case
                                • 30934
                                i was thinking the ram is full of random crap actually.
                                • Dan81
                                  SNES-powered
                                  • Oct 2013
                                  • 1865
                                  • Romania
                                  It does this regardless if there's RAM or not.
                                  I tried running the board as bare as I could (CPU and HSF and nothing more) and the same.
                                  As for the RAM, I tested it using a Corsair XMS 2GB DDR2 stick, so not sure if it's crap.
                                  Main rig:
                                  Gigabyte B75M-D3H
                                  16GB DDR3-1600
                                  Delux MG760 case
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    Did you try it? Or are just guessing?
                                    I've been burnt by silly stuff like that. Pop in a fresh battery (or one you *KNOW* is good) and try it. Don't make assumptions.
                                    sigpic
                                    (Insert witty quote here)
                                    • Dan81
                                      SNES-powered
                                      • Oct 2013
                                      • 1865
                                      • Romania
                                      Yes, I did try it right now.
                                      Same, it will turn on automatically and never power down.
                                      I also measured the power switches and while the reset gives 0, I get a 100ohm reading on the PWR_SW pins.
                                      Main rig:
                                      Gigabyte B75M-D3H
                                      16GB DDR3-1600
                                      Delux MG760 case
                                      • Sparkey55
                                        • Jan 2010
                                        • 1523
                                        Are these ohm readings taken from the switches alone or from the motherboard pin headers? Normally OPEN switches should read as zero ohms when closed (pushed in) and infinite when open (not pushed in).
                                        • qwerty99
                                          Xbox 1.6 Motherboards and Polymer Capacitors
                                          by qwerty99
                                          Hello!
                                          I need to change the capacitors on my three original Xboxes.
                                          Two of them are 1.6B revisions and have Hynix RAM, and the other one is a 1.6 with Samsung RAM.
                                          The 1.6 has the infamous Nichicon HM capacitors around the CPU, which have all bulged and started to leak. This Xbox no longer powers on.
                                          The 1.6B revisions have Rubycon MBZ capacitors that all look fine, but I’ll change them in due course. Both of these work fine.
                                          I’ve seen some excellent threads on the forum about replacing/upgrading capacitors, but I can’t...
                                          06-26-2022, 12:53 AM
                                        • Foetuss
                                          Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                                          by Foetuss
                                          Hi all
                                          Hope this is in the correct place.
                                          I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                                          Could use some double checking to see if I'm not doing something stupid .
                                          Pictures of the boards are attached.
                                          What I will be replacing with what : (planned)
                                          Soltek Golden ::
                                          4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                                          6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                                          01-18-2025, 11:44 AM
                                        • madscientist750
                                          Looking for capacitor lists for Motherboards, Video Cards, Home Appliances
                                          by madscientist750
                                          I would like to ask if there is some kind of capacitor lists for motherboards, power supplies, video cards, audio cards, microcontroller powered home appliances, and so, that i could try to find and download. I use to repair those things and i would find it helpful if i could know in advance what parts may i need for common repairs.
                                          07-09-2024, 09:24 AM
                                        • blues_spirit
                                          practical courses for troubleshooting pc motherboards
                                          by blues_spirit
                                          Hello from France,
                                          mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
                                          Do you think this is feasible for me? I...
                                          12-18-2022, 12:56 PM
                                        • Deby
                                          List of compatible laptop motherboards
                                          by Deby
                                          This is a list of compatible laptop motherboard information that I have been collecting for some time.
                                          And it's still ongoing.
                                          Every time I come across information that a board is compatible with another, I write it down.
                                          Anyone who wants to, can continue to expand the list.
                                          Packed in the rar, is an excel table that has additional information.
                                          Motherboards.rar...
                                          05-31-2024, 04:34 AM
