Gainward Rampage 700 GLH
  • alindumitru46
    • Aug 2015
    • 255
    • Romania
    I received a dead videocard and the first step is to verify the disassembled fans.
    Can you help me with the meaning of fan colors for the vents?! I must improvise custom fans to keep cool the card for booting.
  • alindumitru46
    • Aug 2015
    • 255
    • Romania
    Re: Gainward Rampage 700 GLH
    Solved with the fans.
    • alindumitru46
      • Aug 2015
      • 255
      • Romania
      So dust all over, one of the vents has the sectioned section, both being detached from the owner without knowing how to fit them again. In addition, the thermoconductor paste was badly hardened.
      After a quick cleaning I've reassembled everything but when booting I got the 2A and 2E errors, that's seems to be a bad videocard. One GPU is slightly warming, the first to the left of the image, so seems to work.
      Because this plate is already on a different level, diagnosis and eventual repair are very complex.
      Is it worth the effort ?!
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        I see your video card is a Radeon HD4870 X2, so your issue is probably bad GPU chip. Just re-heat / reflow the card and see if that brings it back to life. If it does, edit and reflash the BIOS so that the fans are always running and keeping the card at no more than 60C temperature under full load... which could be a challenge, given that the HD4870 has a power dissipation of over 250 Watts , if I remember correctly.
        As to weather it's worth it... that depends on how valuable your time is and if you like doing this. That said, HD4870 X2 video cards still have some value in working condition (typically selling for $10-30 on eBay right now). So could be worth a shot with the reflow.
        • emil_t
          RTX3090 working fine but fans not spinning
          by emil_t
          Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
          04-12-2024, 06:54 AM
        • b-slayer
          Asus Strix-G15-G513RM fans don't work
          by b-slayer
          I have an Asus Strix-G15-G513RM, who starts normally, but as the fans don't work, it stops and is really really hot,
          The Bios was the latest one, (327), but I managed to downgrade it to version 325 to see if it changed something,
          (as I read somewhere that a corrupted bios can explane my problem), but nothing, it just went full blow during the downgrade,
          (so now, i can say that the fans are fonctionnal), but as it restarted, the fans won't turn at all again.
          ah, and in the Bios, even when the temperature is really hot, the fan are a 0 rpm,...
          09-04-2025, 04:58 AM
        • JayPoorJay
          Hot Water Rad - A Few ECU Fans and a Timer Switch
          by JayPoorJay
          Good Afternoon, Good People.
          I know this will be an elementary little project for most if not all of you, but I thought I would write a post and get put on track, rather than bumbling my way through it with all kinds of trials and errors.
          I REALLY would appreciate y'alls help.
          This is the problem - My wife and I purchased a big ol Victorian/Colonial House in NYC two years ago. The kitchen is surrounded on 3 sides by exterior walls, there is also a 1/4 of the kitchen floor (ceramic tiles) that has a crawl space underneath, and the kitchen gets FREEZING cold...
          10-29-2024, 12:54 PM
        • sda sad
          my Xiaomi Notebook Pro X laptop fans work like crazy for no reason
          by sda sad
          Hope this is the right place, someone can help me.
          My laptop started having a really strange problem....
          When I turn it on the fans start working at a crazy rate and with random breaks...
          They can work for say 10 seconds and stop for 2 seconds and then turn on again for 5 etc...
          And it's from 0 to 100%. I tried to install AIDA and did the processor chip test and the graphics did not exceed 70 degrees and the fans were not even close to working at the power they work randomly.
          The model of the computer:
          Xiaomi Notebook Pro X 15 OLED (A30)
          04-23-2024, 09:55 AM
        • joesmoe91
          Dell Precision 5530 15" died to blown chip. Replaced chip and now only get momentary fans, lights, no screen or boot
          by joesmoe91
          My Dell Precision 5530 turned off suddenly when I was running Matlab and wouldn't turn on, show any lights, fans, and/or any signs of activity at all. I opened the case, removed the battery and looked at the board with a thermal camera while the AC adapter was connected. I saw that PU1252 was >120C so figured the chip had died on me Got the part number off the attached schematic (see Mouser link below) and replaced the chip. After replacing the chip the board (connected to AC adapter) was able to briefly power on, spin the fans a little bit, and turn on the front led lights....
          02-22-2024, 07:38 PM
