ASROCK 775i65G Rev2.03 / Turns ON / No Display
  • DsB_79
    • May 2013
    • 16
    • Portugal
    hi, i have a asrock 775i65G Rev 2.0 that starts but does not display any image.
    I put a debug card on pci slot and the following hex code appears 13 20.
    Steps that i have tried:
    Reflash bios , i went to the support site of the board and download the dos version to do the reflash, but this does not solve the problem,
    I put external video card on slot agp but the error code is the same so this does not resolve the problem,
    I not sure but i think i have a small short in the 3.3v line because when with analog meter in scale of x1 black probe in gnd and red probe in one of the 3.3 atx line i have 600 ohm resistance but when i plug the vga cable one the vga port of the board there is no resistance mean a short i think,
    I have a variable power supply that i use in the line of the 3.3v the only component that gets warm is the south bridge, is this meaning the component have the short?If so why the board still can turn on and display bios codes in the debug card stopping on the 13 20,
    Can some one help me debug this, i whant to understand if the problem is in this component or not.
    The debug card can tell me if the reset sinal is ok and i think that is ok because on the turn on the led lights one millisecond and then stays off meaning that IC super io resets south bridge and south bridge resets north bridge for the board to turn on all the devices.
    Sorry for the long history, but i need some guidance,
    thanks.
    Regards, Diogo.
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: ASROCK 775i65G Rev2.03 / Turns ON / No Display
    If BIOS starts running, southbridge is mostly ok.
    Also, if BIOS is running, reset signals are OK too (except maybe the DRAM reset).
    On some BIOS, 20 means RAM detection error, so try with other RAM sticks and clean properly the RAM slots. We would need to know which kind of BIOS this is to know the meaning of this POST code.
    • DsB_79
      • May 2013
      • 16
      • Portugal
      Hi, the bios is AMI, i have try clean out the slots and i measure 2.7v in pin 184 of the ddr i also try diferent ram sticks with no avail same error code.The mosfet near the ram slot has 3.3v on the drain but i see 2.7 in the pin 184, i also try remove the ram slot and see if the speaker beeps and it does, maybe you are just right the ram cannot be reset but i cannot find the fault component it can be pwm but i dont know how to measure the component.Thanks for the tip i apreciated.
      Regards,Diogo.
      • piernov
        • Jan 2016
        • 4435
        • France
        Ok on AMI BIOS this is not related to RAM. It doesn't really make sense for the BIOS to hang on code 20 here. I would say it is a dead BIOS or a dead northbridge (that you could try to heat/reflow to confirm).
        At this specific point there should not be any communication with the southbridge, but you never know, it could be the culprit too.
        Attached is the POST code list from AMI.
        • DsB_79
          • May 2013
          • 16
          • Portugal
          Ok,i have reflash the bios but i dont know if has the correct one, can you try to explain how to reflash a bios to this board? I went to asrock support site and download the dos version file and then reflash this file to the bios chipset.
          • DsB_79
            • May 2013
            • 16
            • Portugal
            Piernov i have heat the north-bridge and south max air max temp for 30 seconds in the back of the board wait a few minutes then turn on the board and the same error code 13 and then 20 i have a 4 digit debug card that gives me the previous stop code and the next stop code always stops on the 20 strange thing.
            I have notice something in this following procedure:
            With meter on resistance scale red probe on the orange wire 3.3v and black on the ground i notice some resistance increase maybe fill capacitor but when i plug the vga cable on port i see no resistance and i think that this is a short, what do you think?
            Regards,
            Diogo.
            • ChaosLegionnaire
              HC Overclocker
              • Jul 2012
              • 3259
              • Singapore
              umm... how did u manage to reflash the bios if it wont even post properly or display anything on the screen?
              then dont plug the vga cable in then and see what happens but i expect the post error code to still be the same because as u said the error code is the same even when u put the video card in or not. the post code 13 points to a chipset initialisation issue which must occur first before the video card can be initialised. the post code 20 says its waking from the s2 state... really odd code... did u try to clear the cmos as well? clear the cmos as well and see what happens.
              • DsB_79
                • May 2013
                • 16
                • Portugal
                I have reset the bios, that was one of the first things i do.
                With vga cable on port or off the post code is always the same.
                I have reflash bios with williem programmer.
                • DsB_79
                  • May 2013
                  • 16
                  • Portugal
                  Hi have try with another debug card and the code is 13 when vga cable is connect to on board port vga, with external vga card the code is 58 can someone tell what this means?
                  Regards, Diogo.
                  • pkslowk
                    Debug Card Error Code and Solution
                    by pkslowk
                    Sr. Motherboard Debug Error Code Solution
                    1 Intel 845 E9 Bios Related Problem
                    2 Intel 845 D4 CPU Socket Related problem
                    3 Intel 845 37 Bios Related Problem
                    4 Intel 845 7C Bios Related Problem
                    5 Intel 945GCPE 34 Bios Related Problem
                    6 Gigabyte 845 2 Ram Related Problem
                    7 IBM Server A6 A7 Ram Mismatch Problem
                    8 Asus 845 29 CPU Related Problem
                    9 Lenovo I946 97 C-Mos Jumper related
                    10 Gigabyte 845 A0 CPU Related Problem
                    11 Asrock G31M-VS D7 Bios Related Problem
                    12 Compaq 845 BD-70G B0 CPU Socket Related problem...
                    01-28-2021, 12:51 PM
                  • Stephen
                    MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                    by Stephen
                    MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                    03-15-2024, 09:37 AM
                  • DynaxSC
                    MSI PRO Z690-A DDR4 (MS-7D25) - stuck during boot every second time - debug code 16 & A1
                    by DynaxSC
                    Hi Folks
                    I have an MSI PRO Z690-A DDR4 (MS-7525) which underwent LGA1700 replacement and had a missing resistor in the VRM section. The missing resistor RV170 (49,9Ω) has been resoldered, and I have also replaced a demaged LGA1700 socket.
                    Generally the board does boot to Windows, but not always in the first attempt, but after the second attemp to boot the board with Power Button. Also restarting the board from Windows ends up with stuck boot process, but restarting the board again (long push Power Button or switching off and on PSU). Under Windows etherything works
                    09-29-2024, 04:27 PM
                  • www
                    LG L192WS-BN backlight turns off after 1 second
                    by www
                    I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                    I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                    03-24-2024, 05:26 PM
                  • andrhouseolly
                    Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
                    by andrhouseolly
                    Hi.
                    I kindly ask you to help me solve the problem.
                    Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
                    The board turns on, there is no image.
                    Read more. When the power supply is connected, the front panel indicators light up briefly.
                    When you press the power button, the button indicator lights up. The board works
                    there is no image, there is no matrix initialization, there is no image on HDMI.
                    When turned on, the fans do not spin, but when they warm up they start spinning.
                    When you turn off the button, the fans spin up to full speed for a short...
                    05-11-2024, 03:14 PM
