Asus ROG 751JT Power issues
  • reegs
    • Mar 2018
    Trying to find a schematic for a ASUS G751JT-WH71(WX).
    Problems started with the laptop going from AC to battery and back again when playing games.
    Eventually the battery would completely discharge and not even register the DC jack.
    A few days would pass and it would work again.
    Now there is NOTHING. No lights at all when plugged in. Power button does nothing.
    What I've done/tried:
    1. Replaced battery
    2. Disassembled / reassembled many times ( pulled main / bios battery and held in pwr button for 1+ minutes)
    3. Tested AC - DC power plug and can confirm 19v output (OK)
    4. Tested for 19v at DC mini-board going into motherboard (OK)
    5. No visabable shorts or suspicious items on motherboard. (OK)
    It's 2yrs old, so no warranty stuff.
    I was thinking it could be a blown charging circuit.
    Anyone have any thoughts?
    Thanks for any help you may have.
  • Dark_Raven
    • Aug 2017
    • Philippines
    Re: Asus ROG 751JT Power issues
    Replace Motherboard can solve your problem Man
    • jasonr2000
      Advance Tech
      • Nov 2013
      • 209
      id say try it without the laptop battery in and see if it powers up then ?
      if no go its likely the motherboard has gone bad and would either need repair or replacement
      Samsung UE46D6530
      Samsung BD-F7500
      Samsung HT-ES6200
      • jasko_jacker
        • Oct 2014
        • 1140
        • italy
        Check power pin
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • ShadowAi
          ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
          by ShadowAi
          Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
          Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
          After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
          03-15-2024, 10:46 AM
        • meraklinetx
          Asus Z97-a power cycle, no boot no cpu voltage
          by meraklinetx
          Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
          05-10-2023, 06:08 AM
