Need help/suggestions for a dell recap
  • paradox1156
    • Feb 2009
    • 6
    I have a dell inspiron 1150 that needs a recap. The cap fell off the motherboard, I unsucessfully tried to solder it back on with my basic and obviously inadequate soldering skills. I was wondering if anyone could properly identify the capacitor that I would need to replace it with and how to solder these chip type capacitors on properly (tools, procedures, . From what I have gathered at this site and others I believe the type is a surface mount aluminum electrolytic capacitor.
    Attached are the pictures, for those who can't make out the text on them it says
    4 8
    220
    2 5A
    and then on the bottom there is and S and 78.
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: Need help/suggestions for a dell recap
    I hate surface mounted stuff.
    I know its 220uf, and I bet 48v
    edit: hm ya know I bet thats 4.8v
    • gdement
      • Jan 2007
      • 690
      Looks like it might be a Sanyo CE-AX.
      Markings match it going by the datasheet, and it looks like a Sanyo vent.
      Assuming this is correct, then
      "A" is the series code for CE-AX, and the "25" is 25v.
      "220" is the capacitance (220uF).
      • paradox1156
        • Feb 2009
        • 6
        do you know any places to obtain these sanyo caps? I'm looking online without much success, I've determined that it's either a Sanyo 25CE220AXA or a Sanyo 25CE220AX depending on the size but I can't find a place where I can buy them without waiting 5 weeks or ordering a massive quantity.
        • paradox1156
          • Feb 2009
          • 6
          Or could I go with another brand with the same specs such as this one? http://cgi.ebay.com/8-Nippon-ChemiCo...742.m153.l1262
          Height is kind of an issue though due to it being in a laptop.
          • paradox1156
            • Feb 2009
            • 6
            I also found this but still I'm not sure which one to get due to the measurements heights and width-wise.
            http://www.mouser.com/Search/Refine....774+4294401343
            • varunviolin007
              Looking for someone to recap Dell XPS T450 motherboard (Live in suburbs outside of Philly)
              by varunviolin007
              Hi guys,
              I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
              I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
              Looking for someone experienced with older PC boards who uses...
              07-29-2025, 11:53 PM
            • 0x0null
              Dell Latitude 5530 not properly charging
              by 0x0null
              This Dell Latitude 5530 will not charge when turned off. when turned on and in bios it will charge properly and the adapter wattage is shown.
              I noticed that when in bios if the charger is unplugged the bios still reports the laptop as charging and the charging light in front of the laptop stays on
              When charging, PL4401 has a stable voltage of 12.8V however when plugged in but not charging the voltage alternates between 4v and 12v on PL4401
              Please help
              12-16-2024, 11:06 AM
            • Akhlz001
              by Akhlz001
              09-20-2025, 07:15 PM
            • master3112
              by master3112
              07-29-2025, 01:55 PM
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
