MSI Radeon RX 550 Low Profile 2GB - Bad Chip Help?
  • chris89
    • Jan 2015
    • 69
    • United states
    This chip gets crazy smoking hot when I turn it on now & doesn't work at all... this chip must of fried when I plugged in my PCIe x1 to x16 adapter in backwards in the slot on accident.
    Need to replace it.
    Can you make out what it says or what it is?
  • Sojke
    • Apr 2017
    • 131
    • Serbia
    Re: MSI Radeon RX 550 Low Profile 2GB - Bad Chip Help?
    That´s an 1117A voltage regulator. Had one fried when I plugged in an bad DVI to VGA adapter on an Low Profile GeForce 605. Its an fairly common component on video cards.
    • chris89
      • Jan 2015
      • 69
      • United states
      Thank you
      How do I test if it's bad with a multimeter? just test continuity & resistance?
      Where do I find a replacement & does it need to be :
      1639753 ?
      $0.99
      https://www.ebay.com/itm/1-pcs-New-L...oAAOSwlptZ-lt0
      • jondoe
        • Nov 2016
        • 547
        Check to see if it's shorted to ground. Of the three pins, one will be voltage in, one will be voltage out, one will be ground. If you have a short to ground it should be easy to diagnose.
        I'd take it off the board and check it in isolation, then check incoming voltages on the card pads, i think it should be getting 5 volts on one of pads, nothing on the other, and one is ground. 5 volts might not be right, I'm going on a quick glance of a few datasheets.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          Probe between middle pin and the two others. If you have a short either way, the regulator is toast and needs to be replaced.
          A working TV? How boring!
          • NeedsMoreFlux
            • Oct 2017
            • 121
            • California
            digikey probably has the same brand chip-within the USA-at a good price. and shipping is $3.39
            Disclaimer: Don't trust a thing I say-I am frequently wrong!!!
            I have tons of spare parts, some used, some N.O.S. ham transistors and caps. Message me if you need any parts.
            Some of the things I've fixed:
            60" Vizio-bad LED's. iBook G4: Resoldered VCC Plug. Geo Tracker ECU: Swollen / Leaking capacitors. Windows Laptop: Soldered broken LVDS wires. Dryer: Burned contact on temp switch. Oven in R.V.: Bad contacts in relays-Exploded by the looks of them! Samsung Oven: Burned contacts on Relays. MSI Motherboard: BSOD-Swollen capacitors, bad graphics card, Moved SATA Input from SATA 1 to SATA 2 plug
            • jiroy
              • Jun 2016
              • 2416
              • Lebanon
              A new company's logo , not identified anywhere , probably a cheap chinese one . Referring to standards then , this an LDO Voltage Regulators fixed at 5.3V , as the last suffices indicate .
