Hi guys; i've been pulling my hair out cause i can't figure out how to download files from USB stick to local Android storage,
Transfer Files/apps from USB to Android tv BOX?
Re: Transfer Files/apps from USB to Android tv BOX?
^ Install ghost commander file manager. Its a great app, first built in the 2.3.3 days, its been maintained since and works well. two panel file manager.
https://play.google.com/store/apps/d...stsq.commanderThings I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Follow the white rabbit.Comment
Thanks goonntron; i'll keep that in mind,for now i was able to transfer files but don't ask me how,cause i don't know,next time i'll use your advice if i can,thanks^ Install ghost commander file manager. Its a great app, first built in the 2.3.3 days, its been maintained since and works well. two panel file manager.
https://play.google.com/store/apps/d...stsq.commanderComment
Hi guys;i want share with you a easy way that i 've learned on how to copy or move files from external USB or Sd card to internal storage on Android TV box with pics;
1. download and install ES FILE EXPLORER from Play Store,
2. open ES File Explorer
3. click on External USB/SD drive
4. Files will be shown
5. click Holding file til a ticked box shows
6. go down to the right corner where it says *MORE* a menu will open with
some options MOVE TO,COPY just click on it and move files or copy to where you want.Comment
by GrutHi everyone,
My JVC (Vestel) LED TV is stuck on a Android boot loop when I switch the power on.
Previously, I was trying to clean the storage memory (by deleting as many files as possible), I may have delete some start-up Android files.....so I screw it.🤡
When I switch the power on, the initial JVC is shown. I have tried to run Android 9 from a bootable USB on the TV. It starts reading the USB but nothing happens and the JVC logo and Android boot loop keeps the same.
Can anybody help me please finding the 17MB171 USB firmware to try to upload... -
by mon2Hello. Have a 55" Hisense TV that starts to load the Android OS (no backlight issues) -> reaches the app screen where you can view the assorted icons including Netflix and always crashes at the same point just after this launch. If I quickly press the cursor buttons, the cursor can navigate to the settings menu but will power off just after a few seconds of this activity. Do not believe it is power related since the crash is very accurate in the boot cycle.
After the OS 'crashes', the power does go off and the from white LED goes dark for about 20 seconds and then ON again.... -
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
Hi.
I am starting to learn about UEFI BIOS.
At the moment I have Lenovo laptop with bad BIOS.
I tried to clean ME region and transfer EC region from a known working BIOS, but the laptop does not POST (just fan spin).
So there is something else bad.
If I flash a know working BIOS, the laptop POSTs and boots into Windows.
But the problem is, that the serial numbers, Windows key, and every thing else is from another laptop.
Where do I start to transfer the S/N, Windows key and other information from one BIOS to another?
Thank y... -
by jchonHi I'm having issues trying to get my Sony A1E to power on.
Which made me wonder, how involved is Android in the booting of the TV?
I'm basing this information on what I can glean from the service manual:
In my Sony A1E for example I see:
BKA which houses the main processor and along with the input/outputs.
DKA which possibly does up-conversion, in the block diagram I see VX1 coming in from the BKA and out to the TCON
TCON timing board which drives the actual panel.
On the BKA there's a sub-system called the U-COM...06-30-2023, 01:58 PM - Loading...
