A7N8X bad caps reboot?
  • Bigtwin
    • Sep 2008
    • 5
    I ordered a power supply because I thought my random reboot was due to a bad PS. When I opened the case and shined a flashlight onto the mobo, I found 8 bad caps on my A78NX Deluxe. I guess that's the reason for the random rebooting. Wonder if I'd be better off ordering a combo mobo/cpu and use existing ram?
    (sorry about the crappy cell phone pic) but you can see the crud that has surfaced at the top of each cap.
  • Gianni
    • Jul 2008
    • 681
    • Italy
    Re: A7N8X bad caps reboot?
    I think it depends on you: if you want to try to save it, I think you are going to save some money.
    If you don't have the tools to recap your board, you must ask to someone and see how much it cost.
    If I were you, I would try to recap it, if the only problem/reason you have is "random reboot" .
    Gianni
    "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
    H. J. Brown
    • Bigtwin
      • Sep 2008
      • 5
      Woops, posted in the wrong area. Can admin move this to the Bad caps area under the Aopen-Asus- group of questions?
      • Bigtwin
        • Sep 2008
        • 5
        Regarding the rebooting issue...is it due to the bad caps or the sign of a bad power supply? When I checked the system bios, the 12 volt line was 11.8 or so and the 5 volt line was 4.5 to 4.8 and the 3 volt line was 2.5 to 2.7...
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Either of them can cause it.
          You can have one problem or both problems at the same time.
          Either of them can cause this too.
          Output filers in PSU are in parallel with most caps on mobo.
          Also bad caps on mobo can make PSU caps go bad.
          Bad caps in PSU cam make caps in mobo go bad.
          If you have cap problems anywhere always check both psu and mobo.
          Mann-Made Global Warming.
          - Dr Seuss
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            those voltages are way off.
            try another psu.
            • Bigtwin
              • Sep 2008
              • 5
              thanks guys..I have a PSU on hand so I'll give it a try and post back...
                by momaka
                03-12-2025, 03:42 PM
              • eryjus
                by eryjus
                05-10-2023, 11:21 AM
              • Paxman_Swede
                by Paxman_Swede
                Hello!
                01-14-2025, 09:51 AM
              • captain150
                by captain150
                03-16-2025, 07:34 PM
              • Foetuss
                Gigabyte GA-6OXT :: caps question
                by Foetuss
                Good evening
                I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                But I was also suprised about the bigger boys, which are 330µF 25V.
                Could it be they used 25V caps because they were cheaper / available at that time?...
                02-11-2025, 12:22 PM
