POST clk LED question ?
  • bianchi77
    • Jun 2016
    • 1121
    Guys,
    Can I see 33MHz from clk LED pin on POST diagnostic board connected on PCI ?
    Or the value is something else beside 33MHz...
    How can I know if there's clock on my motherboard ?
    It says on the manual it must be on...
    but sometimes I saw it's off and motherboard is running properly...
    and in different POST it's blinking and motherboard is running ok...
    I saw one, it's not completely on or off.....and the motherboard is not doing anything...so isn't there clock generated from clock generator ?
    I've checked the crystal of clock generator, it's ok, but I'm not sure if the chip is doing the job....and I can't see which pin is outputing the clock for CPU/PCI...since there's no datasheet for that chip...
    Any clues ?
    Cheers...
  • bianchi77
    • Jun 2016
    • 1121
    Re: POST clk LED question ?
    Probably, I can test from pin B2 and B16 with scope ?
    http://pinouts.ru/Slots/PCI_pinout.shtml
    • glovecaps
      by glovecaps
      11-25-2024, 04:23 PM
    • Docus
      Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
      by Docus
      Hi everyone 😀,
      I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
      To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
      Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
      1. I already own the exact same model, but its plastic chassis is badly damaged.
      06-10-2025, 04:24 PM
    • Archimedes
      HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
      by Archimedes
      Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
      Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
      Fans are spinning. Blindly could install windows11 and got the device manager...
      07-30-2024, 05:14 PM
      ASUS P5GC-MX motherboard recap
      by momaka
      Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
      This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
      So here is what the motherboard looked like with its original caps:
      CPU VRM area up close…...
      01-27-2021, 11:59 PM
    • dragon3x
      by dragon3x
      power on.
      Here are some examples :
      switching supply area).
      than 6.3 V.)
      03-21-2025, 02:46 PM
