I have a MSI P4 845PE Max that is the basis of a security surveillance system that is suffering from reboots. I found the culprit to be two failed Teapo 6.3v 1000uf caps located near the AGP slot, see below. The system was adequately cooled (loud) and dust was not a factor due to a filter on the intake. The caps around the CPU are UCC and Panasonic and look fine.
Full shot of board
Failed Teapos
Lower half of board
As you can see from the images there are several of the Teapos spread about the board (mostly on the lower half) all of them of the same type 6.3v, 1000uf (17 in total), and the rest of them look fine. At minimum I was thinking I should pull the caps around the AGP and RAM slots. Are there any I can leave or should they all be pulled and replaced?
Full shot of board
Failed Teapos
Lower half of board
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
