hi guys i have these pc intel, i try to install windows xp, windows 7, windows 8, when is loading it always give me these blue screen error 0x0000005c, i change power supply, rams, 3v batery, cpu, i reprogram bios, nothing work, what cant be the problem that doesnt let me install windows, i even try to run windows live nothing same error.i laso try using a pendrive, nothing ......i try using another hardrive nothing.....thanks
biostar G41D3C cant install any windows
Re: biostar G41D3C cant install any windows
Try to simplify. Just one DRAM stick. Set BIOS back to defaults.
Try a linux CD/DVD. Most linux DVDs come with memtest. Run memtest for a few hours and see if the DRAM or DRAM slot is bad.--- begin sig file ---
--- end sig file ---Comment
by japlyticIn a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
Tried (only with keyboard/mouse connected):- BIOS + database update
- Using latest Windows 11 image built with official image creation tool
- Previous setup version for Windows 11 installer
- Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
- TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
- Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
06-19-2025, 04:59 PM -
by tommy97I have an ASUS FA507R in for repair where I’m unable to install any operating system. The laptop works fine when booted from an external Windows or Linux drive, but any attempt to install on an NVMe SSD fails.
I’ve already tested with three different SSDs (Gen 3 and older), and the issue persists. The laptop originally came in with a faulty SSD showing 0% health....08-22-2025, 07:55 AM -
by rheyntauCAN ANY ONE HELP ME WITH THIS PROBLEM....ASUS C202SA CHROMEBOOK TOUCHPAD NOT WORKING AFTER INSTALL WINDOWS 10 ..IT WAS ELAN TOUCHPAD..I DOWNLOAD A DRIVER BUT ITS NOT WORKING IT SAYS "WINDOWS FOUND DRIVERS FOR YOUR DEVICE BUT ENCOUNTERED ERROR.....THE HASH FOR THE FILE ISNOT PRESENT INTHE SPECIFIED CATALOG......."
by ivtecHas anybody installed Linux on Windows 10 using Virtualbox? and since my old PC will have support after oct 25 and won't update to 11 , i just want to use win 10 for Music notation program and use Progdvb iptv player .
by bohabohaHello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encountered an error.
but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
any help?-
- Loading...
