hp pro 3420 daowj5mb6e0 shorted.
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    hi all, i have this all in one computer that has a short or i think so, because when i plug power supply psu led start blinking. tried another psu with same result.
    if i check pq127, pins 5-6-7-8 are shorted. if i remove pq125 led wont blink, but i need a schematic to fix this one.
    mainboard is quanta wj5 or hannstar mv-6
    best regards.
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    Re: hp pro 3420 daowj5mb6e0 shorted.
    finally with psu lab i found bad component. it was pq82 : 73t03gmt 13136g, but cant find that component to buy....
    edit i found it's a AP73t03gmt n channel mosfet, but i need asap and express ship is 40$.... so im wondering if there are any compatible mosfet that maybe i could find in my country..
    edit: while wa looking for an equivalent, my supplier told me it was in stock
    • dellxps15
      • Feb 2014
      • 1598
      • italy
      mosfet arrived and replaced just the one shorted. now pc power on, but when loading windows it do osme dots and then stop working. after a while give me bsod about a page fault. tested hdd all ok. tested ram all ok. that make me think
      1) bad gpu on cpu
      2) have to change also other mosfet that could get damaged...
      ps: sometimes pc doesnt post after a reboot.... if i turn it off then on i got the hp logo.
      • dellxps15
        • Feb 2014
        • 1598
        • italy
        got another cpu and now is fully working
        about bad post: removed ram, put it back and that issue is fixed too
        • Nooy
          VGA MOSfet permanently shorted and loss of MOSfet pad
          by Nooy
          Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
          I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
          02-14-2024, 02:26 AM
        • chestercc
          Alienware M18x Shorted CPU Mosfet
          by chestercc
          I've got an old Alienware M18x R1 which shorted out the charger whenever it was connected. Tracked down the short to two shorted caps and burned CPU power controller caused by a shorted mosfet on the CPU's graphic power supply.
          I've replaced the faulty mosfet, two shorted caps and the CPU Power controller (NCP6151S52MNR2G).
          Issue is now whilst there is no short if I attempt to power the system on the fans spin for a couple seconds there are no lights and no further action - the PCH is heating up but there is no CPU power coming out but there is an enable signal...
          07-16-2022, 06:05 AM
        • mat2k
          iMac 2017 PSU - shorted PFC mosfet
          by mat2k
          I am trying to fix an iMac 2017 PSU, initially came with a blown fuse and shorted PFC MOSFET (6R199P). After visual inspection and some measurements I replaced the FET with a P20NM60 and tested with 100w series lamp, and it lasted 1 second before going into dead short. The PFC controller chip (NCP1605BG) and its passives appear fine (passives measure OK), but I do not know if there is a simple way of testing the NCP1605 as I wouldn't like to blind-replace it.
          There was some slight blackening of the solder on the PFC controller passives so I reflowed them all with some flux. I am waiting...
          03-13-2025, 11:31 AM
        • daemon123
          MSI GTX-980ti shorted MOSFET on memory rail
          by daemon123
          Hi All,
          I have this MSI GTX-980ti Gaming Golden Edition. It had shorted mosfet on memory. Replaced the shorted i.e. Q47 PK616BA with 4C09N and the card ran fine for a month. Then suddenly again the same problem. This time when i replace it 4C09N or with replacement PK616BA (Aliexpress) it gets shorted. As soon as turn on the PC the PSU shuts down and the same mosfet Q47 gets short.
          What should be the next step. Kindly guide.
          The board view files for this gpu is available and attached. https://www.badcaps.net/forum/showthread.php?p=1237952...
          05-10-2023, 11:05 AM
        • Jane
          How do you test MOSFET in laptops ?
          by Jane
          I tried to use this method:
          Testing an N-channel MOSFET:
          Step 1: Discharge the Gate (turn off the MOSFET)
          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
          Step 2: Charge the Gate (turn on the MOSFET)
          Now, place the red probe on the Gate (G) and the black probe on the
          09-27-2024, 03:31 AM
