Dimension 8400 with bad HN(M)'s
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Was a bit surprised at this one. Board is fairly recent.
    P4 3.0ghz
    WD 160gb SATA HD
    PCIe video card of some type
    Originally shipped from Dell 8/9/2004
    The Nichicon on the cap got blurred by the coil reflection.
    All redone in panny FM's.
    Original bad caps was a single 2200 6.3v and then (5) 1000uf 10v. I replaced the 1000 10v with 1200uf 10v because that was the closest thing I had in stock. PC runs great now
    Ludicrous gibs!
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Dimension 8400 with bad HN(M)'s
    hn/hm are known bad caps.
    ala gx270 boards.
    100% fail rate in a year for several big customers.
    • bgavin
      • Jan 2007
      • 1355
      I know there is supposed to be a date range from bad ones, but I toss out all of 'em, no matter what.
      • Wizard
        • Mar 2008
        • 2296
        2004? That's not recent. In terms of computer stuff, that's "considered" old and I take advantage of that to get socket 478 boards and cpu rather cheaply so I can upgrade our shop's computers from ANCIENT PII/Celeron/PIII mix. My pc was Athlon 3000+ with A7N8X in 2004 and finally replaced with Asus P5K and E2200.
        Toss boards with bad caps out? You mean swap the bad caps off with new caps?
        Cheers, Wizard
        • dood
          Deputy dood
          • Mar 2004
          • 2462
          I hear ya, wizard. But with PCI-express and SATA native on-board, it's "new" to me. I'm still running a socket A AthlonXP system for my primary. With good old AGP! And, the only way I have SATA primary HD and optical is because I bought a controller card for them.
          Ludicrous gibs!
          • bgavin
            • Jan 2007
            • 1355
            I'm still on Socket A also. MSI boards, 400 FSB, DDR-400, AGP8x.
            This is changing, as I have an E8400, GA-P35-DS3, DDR2-800 on the bench right now. I'm tinkering with the ideal fan combination for the Scythe Zipang heat sink I got for this board.
            It's about ready to install the OS. I have to build this machine offline, as it is replacing my primary workstation. I cannot have this machine down for a few days while I build the new one. Push/Pull arrangement.
            As to the Nichicons... I recap them as a matter of course. Bye, bye. I've done a number of 8400s for my clients. Both dead and preparing to die.
            • geforcefly
              • Jul 2006
              • 33
              I ran into the same exact situation with a Dell Precision 370 (which uses the same motherboard as the Dimension 8400) so they aren't immune to the dreaded HN(M)s either.
              • dood
                Deputy dood
                • Mar 2004
                • 2462
                Just got another one of these in for recap.
                Ludicrous gibs!
                • Wizard
                  • Mar 2008
                  • 2296
                  Whoops, I meant my P5K is my home main PC, and my work pc here is Dell Dimension 8300, yes HM cap in a row were burst. Replaced and tested with prime95 passed. Now running 2.8C.
                  Eventually replace that one as well. It's kind of "feeling sluggish".
                  Cheers, Wizard
                  • MrVik
                    • Apr 2009
                    • 18
                    Hi dood. I have to recap an old Dell Dimension 8400 and would appreciate a cap list if possible. The computer is in service and I don't want to shut it down until I get the parts. Thanks for any help.
                    Why throw it away? I might need it in the next 40 years. Duh!
                    • Newbie2
                      • Sep 2005
                      • 885
                      It's recommended to stop using a PC with bad capacitors on the motherboard, otherwise there is a chance the problem can get much worse.
                      My gaming PC:
                      AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                      ASUS M4A77TD AMD 770 AM3 Motherboard
                      PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                      G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                      TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                      WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                      ASUS Xonar DG 5.1 Channel PCI sound card
                      Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                      Antec Three Hundred Mid-Tower Case
                      Microsoft Windows 10 Pro 64-bit
                      Microsoft Windows 7 Ultimate SP1 64-bit
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        yeah. a board with bad caps can be fixed, a board burnt up because someone didn't replace the caps is a paperweight. and a potential fire hazard
                        sigpic
                        (Insert witty quote here)
                        • bgavin
                          • Jan 2007
                          • 1355
                          Board Rev Cap Mfg Series uF Volt ESR Dia Len Count
                          02U819 - Dimension 8400 A01 Nichicon VR 470 16.0 8.0 2
                          02U819 - Dimension 8400 A01 Fujitsu M Yellow-K 560 4.0 8.0 12.5 5
                          02U819 - Dimension 8400 A01 Rubycon MBZ 820 6.3 8.0 13.0 2
                          02U819 - Dimension 8400 A01 Rubycon ZL 1000 6.3 10.0 14.0 1
                          02U819 - Dimension 8400 A01 Nichicon HD 2200 16.0 12.5 25.0 2
                          02U819 - Dimension 8400 A01 Nichicon HM 3300 6.3 10.0 25.0 4
                          • MrVik
                            • Apr 2009
                            • 18
                            Thank you very much bgavin, this will save me a lot of trouble. I appreciate your help. The first cap in your list, Nichicon VR 470, what is the voltage or am I just missing something? Thanks again.
                            • 370forlife
                              Large Marge
                              • Aug 2008
                              • 3112
                              its 16...wait...
                              • MrVik
                                • Apr 2009
                                • 18
                                Oh, I think I get it now. I might be too old and slow for membership on this board. Guess the "yoke" is on me, ha, ha. Bye.
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  its ok. too bad this forum has no table function
                                  sigpic
                                  • bones41
                                    • May 2010
                                    My Dell Dim 8400 has a cap that looks simular to the one in the picture next to the coil. It has the same specs. Can you tell me were to get the same one. I have not seen any others that look like they are bulged.
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      brand?
                                      sigpic
                                      • bones41
                                        • May 2010
                                        brand?
                                        It is a Nichicon 2200uf 6.3v and it says 22 Ho 422 on the side
                                          FUJITSU ESPRIMO Q558 ESPRIMO Q i5-8400 Specification for Upgrade or Repair
                                          This specification for the FUJITSU ESPRIMO Q558 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ESPRIMO Q558 boardview and ESPRIMO Q558 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for FUJITSU...
                                          09-12-2024, 03:44 PM
                                          DELL Vostro 3470 Vostro 3400 i5-8400 Specification for Upgrade or Repair
                                          This specification for the DELL Vostro 3470 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3470 boardview and Vostro 3470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
                                          DELL XPS 8930 XPS i5-8400 Specification for Upgrade or Repair
                                          This specification for the DELL XPS 8930 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPS 8930 boardview and XPS 8930 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 8930 is accurate,...
                                          FUJITSU ESPRIMO P558 ESPRIMO P i5-8400 Specification for Upgrade or Repair
                                          This specification for the FUJITSU ESPRIMO P558 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ESPRIMO P558 boardview and ESPRIMO P558 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for FUJITSU...
